Old 27th May 2004, 01:33 PM   #1
destroyer X's Avatar
Default Thinking in buy a Kit...500 bucks will fly.. and heat?
I starting to think in buy a kit to have clean boards...pretty material and good sound to test.
I have those pieces of heatsink, they were separated in two parts because i do not use insulators, better without them, also i do not sleep with pants too...not adequated to cooling.
My experience, without calculations, because i study Psychologie to scape from Mathematics, is that a squared piece of aluminium, 2 milimeters thickness, 10 centimeters side....positioned correct to convection cooling, air temperature around 29 degrees centigrades is enough to 10 watts.... so, 100 squared centimeters enough to 10 watts heatsink..... learning doing an burning!
Made those calculations and concluded that this 850 square centimeters parts (2 parts... total 1700 square centimeters) can be good to 170 watts of heat dissipation, without cooler, in normal convectional cooling position and those parts are glued with epoxi cement on wood insulators to keep positive rail separate from negative rail.... thinking in around 35 or 40 volts amplifier and power around 50 Rms.
Hello friends, and enginneers, also audioholic, audiomaniacs and whole family... will this heat sink be good?
BUT I will send it to mechanics tool to rectified surface... and will use other transistors than 2N3055 capsules...i know the holes are too big....made in sixties...i was young and with less knowledge...loose material...bad heat transfer...i know that. Surface will polish into mirror and anodized electrically, do not know color result from that.
Tell me some, please, where's a mistake?
Are there a mistake?
Carlos
Try to build an amplifier folks ... it is pure adrenaline!
Old 27th May 2004, 01:36 PM   #2
Default Other side of heat sink
Here is... will be pretty.
Carlos
Old 27th May 2004, 01:39 PM   #3
Default Other image, other side.
Here's image.
I will send to mechanics, with rectifying tools.
Carlos
Old 27th May 2004, 01:50 PM   #4
li_gangyi's Avatar
you can test it out without calculations by putting a power resistor on it...and then applying some voltage..that way it will be easier...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 27th May 2004, 06:41 PM   #5
Default Yes! .really...i will try this way
Yes, i was thinking in a soldering iron...but your idea, resistor squared.... some can you screws and silicon thermal compound is much better.
Thank you
Carlos
From Bucks County, PA, U.S.A. editorjuno Introductions 3 27th July 2009 05:07 PM
Did I waste my bucks? bulgin Solid State 12 31st May 2008 10:27 PM
PE sub amp 200W for 99 bucks AJ Bertelson Subwoofers 0 29th December 2003 02:53 PM
Page generated in 0.08296 seconds (69.94% PHP - 30.06% MySQL) with 11 queries
