how do i measure the power or the "Va" of my transformer?
(35V transformer, looks powerful...) |
#2 |
in the schemic of the power supply(P3A) there are 3 wires from the transformer(-35, GROUND, +35) but i have only 2 wires coming out from the transformer... what can i do?
how should i connect it?can i? |
#3 |
You cannot use the transformer unless it has 2 seperate secondary windings, or a centre tap (3 wires). You will be unable to generate both the negative and the positive voltage with only one tap.
#4 | |
#5 |
and...how can i do that?
is it complicated? |
#6 |
how is it possible ?
#7 | |
What ever makes the tunes flow |
#8 |
Well, the following voltage doubler does generally work.
BUT for power applications this is a poor choice! The caps are only charged once per AC-cycle, while the standard full bridge rectification charges the caps two times per AC-cycle. If we charge less often and have longer time between the charging, then we get the following drawbacks: 1. Voltage ripple of the rails increases. 2. Ripple current load of the caps becomes high. 3. In relation to the power, the current peaks in the diodes and the transformer are unfortunately high. Bye Markus |
#9 |
Ahh... I'm still learning
Yeah I can immediately see the high ripple this would have. Not really good for an amplifier! |
#10 | |
ps benmanf i have recieved an email from u but i cant reply because yours is not working |
| Using mains transformer as output transformer | Elias | Tubes / Valves | 175 | 3rd November 2009 08:36 PM |
| Modulation transformer for a driver transformer? | ironradio | Tubes / Valves | 6 | 28th December 2008 05:05 PM |
| filament transformer vs plate transformer | contaxchen | Tubes / Valves | 10 | 14th January 2005 10:43 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 08:57 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
| Page generated in 0.11253 seconds (73.72% PHP - 26.28% MySQL) with 11 queries |
