Hi!
Any comments on my PCB layout and how to improve it? Is the grounding good enough wth the jumpers? The pot is a Noble 50K dual log. |
#2 |
Here is the schematic:
#3 |
Read this thread if you want to read more about this preamp and others who have buildt it.
#4 |
Electrons are yellow and more is better!
I think the layout is fair but somehow I don't like your efforts to create a groundplane. Probably it will work fine but I would still suggest that you have ground under the opamps and two traces with v+ and V-, close to the IC's. I would also suggest compactness and smaller parts if possible.
Maybe you should have the BUF's close to the outputs of the opamps? Try to get the physical layout similar to the schematics. Why don't you consider a pcb with groundplane? If you are going to make it yourself it's real easy with a groundplane. Just put brown parcel tape on the upper side. Se picture below.
/Per-Anders (my first name) or P-A as my friends call me |
#5 | |
Schematics here
#6 | |
Hi, Are you sure you need R5 & R15? It negates the effect of the buffer. What's the value of those resistors? Jan Didden
/Another new issue: Linear Audio Volume 3! |
#7 | |
Maybe I'll do that, and have all ground on top layer. |
#8 | |
50R |
#9 | |
tape etch drill a bit with 3-4 mm drill very easy
#10 | |
| AD8610, OPA134, OPA627, BUF634 SMD headphone amp | peranders | Headphone Systems | 72 | 29th June 2011 07:20 AM |
| Anyone interested in PCB's for OPA627/BUF634 based headphone amp? | Maxhawk | Headphone Systems | 24 | 17th December 2010 04:32 PM |
| My opa549 amp and opa627+buf634 pre | Alcaid | Chip Amps | 40 | 22nd June 2006 03:21 AM |
| YardBird OPA627/637 BUF634 preamp/headphone amp | Russ White | Headphone Systems | 4 | 23rd November 2005 01:53 AM |
| Page generated in 0.10667 seconds (79.22% PHP - 20.78% MySQL) with 11 queries |
