NAD 3020/7020 sound drop-out
Old 25th May 2004, 10:29 AM   #1
bardsleyh is offline bardsleyh  United Kingdom
Default NAD 3020/7020 sound drop-out
I have recently moved on from my NAD3020 but my friend still has a 7020 with the same long-running fault as me - sound drop-out at low volumes. I used to think it was a speaker problem as fiddling with the speaker-wire grips often cured it temporarily, but both of us have found that also fiddling with the amp's phono output also does the same. It is a very annoying problem. Is this a known fault with this amp, as it seems more than coincidence that we both have had it?
Old 25th May 2004, 10:56 PM   #2
cpemma is offline cpemma  United Kingdom
After all these years, general oxidation of the phono and speaker contacts may be giving poor contacts, they're very basic (cheap). I had to re-solder one phono where the joint had cracked, so that's something to check.
A good clean of the switches and pots may also help.
Old 26th May 2004, 12:23 AM   #3
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
I have had 3 or 4 of these nad amp's there great little amp's.. i would get the speaker out puts connectors and the input connectors RCA's re soldered.. also maybe put some volume cleaner in the volume pot.. that might be the problem.. Also these pots that are used are pretty cheap you might have to replace it.. come to think about it.. try this also..
turn the amp off.. then take the volume control and turn it to the left full then to the right full do that about 20 times and then re try your audio see how that goes.. might just be a dirty contact on the control..
Let us know..
Jason.
NAD 3020/7020 sound drop-outHide this!Advertise here!
modify an NAD 7020? peace brainerd Solid State 4 2nd February 2009 05:05 PM
nad 3020 clicking sound when playing islanddancer Solid State 16 13th September 2008 06:33 AM
Orange drop types/sound lndm Parts 3 20th March 2006 03:46 AM
about the difference in sound quality between the two NAD amps. 3020 and 3225 tube shop Solid State 4 4th September 2005 08:33 PM
NAD 7020 help avivz Solid State 4 26th April 2005 11:16 PM
Copyright ©1999-2017 diyAudio
