Hello I am building the esp subwoofer filter :
http://sound.westhost.com/project48.htm and my problem is how could I use polarised capacitors to make a nonpolarised capacitor of 4.7uF that is very large about 5 cm long and 1cm wide.The only ones I could find were rated 400 Volts and had those dimensions. Is this posible to achive? Thanks |
#2 |
Why do you want to use polarised caps for this?
Use a film cap, polypropylene would have the size you want |
#3 |
I know that there are this kind of capacitors but I can't find any to buy...I went to 3 diferent stores and didn't have any that the huge ones, and any polarised capacitors.And this is why I asked the question...
#4 |
Take two electrolitic condensers, the one that have polarization, put plus with plus, or minus with minus.... two 10 uf units will make a non polarized 5 uF....... also two 22 uf will make one non polarized 11 uf....if big values.... you will have some inductance because internal condenser construction is alike a coil.... this way you put a parallel 0.1 parallel unit with them to guaranteed hi frequency will pass..... coil an make some resistance to hi frequencies.
Carlos
Try to build an amplifier folks ... it is pure adrenaline! |
#5 |
When you put two condenser in series, the voltage capacity doubles.
This way, two 10uf / 50 Volts condenser will make one unipolar, or no polarized, of 5uF / 100 Volts. Normally, measuring the capacity is always bigger, and the voltage capacity also. If sound better or worst, i cannot say, but it will work. Carlos
#6 | |
Two 50V unipolars make one 50V bipolar, DC ratings, for AC ratings degrade to 35V. |
#7 |
I and other milions are making this conections without explosions, may be luck! (this is ironic...yeaaah!)
Carlos
#8 |
Thanks all for replying guys!!!You have been very helpfull.
#9 |
Was happy to help you in something.
Regards, Carlos
| Another stupid question! | Dxvideo | Chip Amps | 7 | 20th May 2007 03:46 PM |
| ok, stupid question probably | the-eliti | Multi-Way | 6 | 23rd January 2002 04:17 AM |
| Page generated in 0.10203 seconds (76.95% PHP - 23.05% MySQL) with 10 queries |
