Old 22nd May 2004, 09:00 AM   #1
Send a message via AIM to roofingboom
Default volume control and line out questions
i have to questions
first of all i built an amp with a diff pair input,class a driver,and class b output stage
am wandering where i would put and how to implement a volume control?
would i put a pot in the feedback or what?
also second question is on this amp if i want a rca line out do i just run the line in to the line out with wires?
maybe stupid questions but i am wondering
Old 22nd May 2004, 11:23 AM   #2
Do not foll around with feedback loop, it must remain as the original desing, if you change feedback ratio the amp may run into oascillation and the input stage will overload.
You should go to the " leach low tim" page to see what should be done to set in a volume control.
If you are adding wiring in the input of the amp it must be made with shielded wire to prevent noise induction, and there is special care about ground loops with the shield: basic rule is that the shield of the wire must be grounded only ay one end at the source of signal if there is already a ground path, and if there is no ground path the shield should be connected at both ends.
Transformer volume control questions. gsd Tubes / Valves 18 4th March 2009 02:33 PM
Line-level Volume Control Possibilities crosswick Instruments and Amps 1 27th February 2009 01:21 PM
passive line level volume control CharlieM Planars & Exotics 1 9th March 2008 01:43 AM
Line level volume control rs1026 Chip Amps 9 22nd May 2005 06:18 PM
Volume control questions Prune Digital Source 0 2nd June 2004 10:53 AM
Page generated in 0.06691 seconds (71.70% PHP - 28.30% MySQL) with 10 queries
