Old 21st May 2004, 10:35 PM   #1
Wagener is offline Wagener  South Africa
Default 231 hfe of MJ15004
I have bought a few MJ15004's and MJ15003's. 6 of the 8 MJ15004's had a hfe of 240. other two had hfe of 2 and 118 respectively.
MJ15003's had hfes of 33, 38, 75, 25, 35, 36.
These were all measured with the same dmm.
The MJ15004 with 2 hfe I can send back right?
How about the high hfes?
I am going to use these as the driver stage in the leach amplifier.
Is it ok to use the complementary pair with different hfe's?
I don't think these are fake because I got them from a trusted source.
Old 22nd May 2004, 02:58 AM   #2
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
The hfe figures you quote for the MJ15004s all sound way too
high or too low. Measure them again, and use a different
meter if you get the same results.
I rebuilt my Leach amp using MJ21193/94s, which work just
fine.
Old 22nd May 2004, 08:17 AM   #3
Default Re: 231 hfe of MJ15004
Uhm, as drivers?
Could you elaborate on this? Doesn't exactly sound like
you're actually building a Leach amplifier, as the drivers
are normally specified as MJE15030/31s, I think.
Old 22nd May 2004, 10:43 AM   #4
Andypairo's Avatar
These are mine, which are surely genuine parts.
Will measure their Hfe and then compare it with yours.
Cheers
Andrea
Old 22nd May 2004, 10:54 AM   #5
Thanks Andrea. That will be greatly appreaciated
Old 22nd May 2004, 11:34 AM   #6
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
u cant measure the hfe of power transistors using your dmm!
i guess u got a dmm with a small socket to measure the hfe ,right?
well this socket is to measure hfe of only small signal transistors, u gotta use higher currents to measure the hfe of a power transistors.
ps those are power transistors not drivers
4 each of MJ15003/MJ15004 Stu Swap Meet 2 27th April 2008 08:34 AM
MJ15003/MJ15004 100mS SOA Donk Solid State 2 15th January 2008 04:37 PM
MJ15003's and MJ15004's For Sale mbonham Swap Meet 5 7th December 2006 10:13 PM
Mj15003 Mj15004 jackinnj Swap Meet 0 29th June 2003 10:19 PM
Leach Amp: Matching MJ15003 and MJ15004 swede Solid State 10 26th December 2001 06:37 AM
Page generated in 0.08142 seconds (84.63% PHP - 15.37% MySQL) with 11 queries
