Can I use 1n4007 instead of the 1n4004 diodes?
this is used for thermal runaway protection in the leach amplifier. the diodes are mounted in the heatsink |
#2 |
Yes, although it's somewhat of a waste. The 1N4007's are high voltage.
dave |
#3 |
The difference in cost is about $0.02 between the two. As long as you are over 3 times the voltage in the circuit you are safe.
If it sounds good... it is good! |
#4 |
I think the threadstarter asked if 1N4007 has the same function as 1N4004, he might happen to have just these...
For heat sensing the diode is forward biased and don't need a high voltage resistance in normal case if it's not going to experience backwards bias voltage of higher value. to the issue, I can't for sure answer on your question BUT a higher voltage diode USE TO HAVE larger forward voltage drop, you should of that reason try to find 1N4004, or else trim in your tempsensing with 1N4007, in other case it might happen it wont protect because the 1N4007 won't decrease enough at high temperature so the circuit will eventually not protect from overheating! Disclaimer: In the case of Leach amp, I don't now how it look like there so my answer is in general. Cheers
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears" Michael 29th January 2010 |
#5 |
Banned
ultima, is there also smoke in tubes?
#6 |
Ich glaube so, aber nicht sicher, und do?
#7 |
Banned
when i destroyed them the smoke did not come out
#8 | |
Here in Sweden we say "no smoke without fire", so I guess transistors glow too if there is smoke inside them, but we cannot see it. As for the leach amp, I think it is an accurate description that it has a Vbe multiplier, with four diodes and a resistor (actually two for some reason) from C to B and a trimpot from B to E. The diodes are mounted on the heatsink, not the transistor. I think, but am not 100% sure, that it wouldn't matter which diodes are used as long as the trimpot is adjusted correctly. |
#9 | |
produce smoke for me have stayed in one piece, while those who have "rapidly disassembled" themselves have not produced any smoke. |
#10 | |
Banned
you need: a small transistor like BC546 etc, a Märklin Transformer from toy railway. The package cracks, it glows inside, then it smokes like hell. you need to tune up voltage slowly. I made this with about 10 or 12 years. explosions without smoke i had very fine with capacitors. |
| Biasing/thermal compensation of Thermal Trak transistors | Bob Cordell | Solid State | 156 | 11th December 2010 08:38 PM |
| Thermal runaway question | ricsmuts | Car Audio | 39 | 22nd May 2008 03:03 PM |
| thermal runaway problem | Dan2 | Solid State | 6 | 25th March 2008 07:11 PM |
| Will a true class B have thermal runaway? | azira | Solid State | 46 | 31st January 2004 09:57 AM |
| Transistor Thoery Help. Thermal Runaway | hugeli60 | Pass Labs | 1 | 1st June 2003 09:29 AM |
| Page generated in 0.11238 seconds (81.45% PHP - 18.55% MySQL) with 10 queries |
