#31 |
Thanks, EVA.
Are the equations for half-bridge the same as for full-bridge? About toroids, I can understand that isolation can't be as good as with ETDs. But what if a coated ferrite is chosen, so no problems with the primary, and then add a layer of isolation tape or something like that, then the secondary? Is there some other problem I am missing? And about the number of turns, well, 48 : 4+4 is not very different of what you need in a car supply. At most, you would need 48 : 7+7 for +/-40V output or so at 320VDC, right? Thanks! Sergio from Madrid |
#32 |
I was trying to point out that applying a layer of isolation tape to a wound toroid is a real pain, not to say about applying two or more isolation layers due to sandwitching
About your calculations : You can't assume 320V DC rectified mains since mains voltage fluctuates and sags badly at full load, even falling to 200V DC. My calculations were for a full bridge transformer-coupled buck converter [regulated]. I strongly recommend regulated output. For a half bridge take half the DC rectified input voltage |
| Ferroxcube ETD39 3c90 | guitar_joe | Parts | 0 | 7th July 2007 08:16 AM |
| Max power through 3C90 ferrite 1.52sqcm | Bosium | Car Audio | 4 | 6th October 2005 08:45 PM |
| Page generated in 0.07245 seconds (66.64% PHP - 33.36% MySQL) with 11 queries |
