Voltage regulator OP249 question
Old 19th May 2004, 12:38 PM   #21
Fred Dieckmann is offline Fred Dieckmann  United States
diyAudio Retiree
Default Its like this lattice of coincidence
Originally posted by mfr
Git a reply from China: (relevant text)
----start---
The polarity of K246 please insert like the white silk screen components outline show on the pcb.
The voltage output only -3.74 or other is too low, change the K246 to K246GR, if the voltage is stil un-normal you can change the fet to zener diode.
The pcb of the DAC38 is fully tested and working good.
Hope it may solve your problem.
----end---
As I mentioned before the K246 is marked on PCB as reversed from schematics - Drain/Gate connected together instead of Source/Gate.
The jfet is symmetrical and it should not matter......... at least according to John Curl! I guess maybe I was a good troubleshooter on the rest.
Old 19th May 2004, 01:17 PM   #22
diyAudio Retiree
Default For future reference..........
Originally posted by janneman
The easiest way to get exactly (more or less) 5V is to replace the zeners with floating integrated 5V references. Search the sites of Analog Devices, LTI, Texas etc, there's tons of them. They are more accurate and have better (lower) dynamic impedance than zeners which means better regulator performance.
For example, the ADR550 will beat the hell out of any zener regulated supply.
Jan Didden
And lower noise. I would put a cap in the range of 470 uF to 1000 uF across the voltage reference, very close to it. For a very fast op amp you may want to add a 0.1uF cap in series with a 10 ohm resistor network across the reference and electrolytic. Short leads and small 0.1uF cap (50 V MKP should work well). A voltage reference uses feedback and will most likely be unstable inside a feedback loop with no cap or too small a value cap across it. Use a low voltage cap just a little over the voltage of the reference for low Q and low inductance. Something like a 50 V high Q ( low ESR cap) will be both inductive and likely the resonate with the inductive output impedance of the reference. Think of it as a noise filter AND a zobel network. LM336 impedance vs. frequency below:
Pretty much no charge with all the dead beats here.........
Old 19th May 2004, 01:22 PM   #23
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Hey Fred,
What do you charge as a ghost writer?
Did you identify my avatar yet?
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 19th May 2004, 01:44 PM   #24
mfrimu is offline mfrimu
Interresting, but forgive my lack of certains basics, such as how to connect a zener instead if the FET? I'm not at the level of understanding transistor bias, FETs and the maths behind these circuits.
I have learned a lot throught these postings + reasearch on regulators etc, and I must thank you all for the input.
Here is an attempt at putting zeners instead of the FETs (attached). Is it correct?
As for the integrated 5V references, i'll have to order some, but I would like to try the zeners today.
Old 19th May 2004, 02:18 PM   #25
diyAudio Retiree
Default Did I mess up.........
The zeners replace the 2K4 ohm resistors to the output of the op amps. The direction shown is correct. Leave the 2SK246 jfets where they were. Sorry if I confused anyone.
For some good regulator background:
http://tangentsoft.net/elec/opamp-linreg.html
http://home.comcast.net/~walt-jung/w...ed_PN_Regs.pdf
http://home.comcast.net/~walt-jung/w...g_Circuits.pdf
Old 19th May 2004, 04:01 PM   #26
Jocko Homo is offline Jocko Homo  United States
Banned
Default Interesting circuit.....
Too bad I missed it first time around.
"You did, Oscar, you did."
Why didn't you come up with it, Phred?
"It was one of Wilde's!"
"I wish that I had come up with it."
"You will Oscar, you will."
Etc.
Old 21st May 2004, 02:25 PM   #27
Default Working well!
Here are the results:
Bias resistors 668 Ohms
Zeners 5.1v (measured at about 4.7v)
Opamps outputs (using 10v zener instead of 2.4k)
+ side 4.31v
- side -4.33v
Regulators are working at zener voltage !
After further measurments it looks like the zeners I was using were way off: 4.6v instead of 5.1 and they required more current. I have some other zeners (same wattage) and these are closer to specified value and do not require as much current (tried them with 1k, 2.4k 4.5k bias resistors), almost the same output. I settled for 5.6v zeners (measured at 5.25v) with 2.4k bias resistors: Regulator output at + and - 5.25v
Thanks for help !
Old 21st May 2004, 02:41 PM   #28
jan.didden's Avatar
Looks good!
Just out of curiosity, when you say 'opamps output' you mean the output pins or the pass transistor base? In the final circuit, what is the actual voltage on the opamp output pins? I guess you put the fets back in?
Jan Didden
Old 21st May 2004, 06:37 PM   #29
Just re-measured another PS:
Output voltage is +- 4.97v
Opamp output pins 4.13 and 4.17
On the FET side 5.54 and 5.57
Old 21st May 2004, 09:21 PM   #30
jan.didden's Avatar
So, that's about 1.4v across the 2.4k or .6mA, that's the reserve for driving the pass xsistor if the supply is being loaded. Was this measurement under load? What load?
Assuming an Hfe of 100 of the pass xsistor gives you about 60mA load current spare. Is that enough? What's the raw input voltage at the reservoir cap?
Jan Didden
Voltage regulator OP249 questionHide this!Advertise here!
Novice Voltage Regulator Question slor Tubes / Valves 39 19th January 2008 06:12 PM
Tell me your experience with OP249 serenella Chip Amps 0 25th December 2007 01:19 AM
Newbie voltage regulator question imperfectcircle Solid State 3 25th February 2007 03:37 PM
Voltage regulator help! kasra Solid State 7 23rd November 2002 02:07 PM
