Why are these fuses blowing
Old 18th May 2004, 07:29 PM   #21
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
The PT7 devices are probably a standard device that Cyrus mark up with their own number. TIP41C have been used in many nice amplifiers and should be fine. If you wanted to go better than that you may be able to find a suitable Japanese 2SCxxxx device, but these are generally hard to find. If you buy all the transistors as I suggested you will be in for a bill of about £10.
Can you give a clue as to how the amp blew? Was it broken when you got it?
Old 24th May 2004, 06:09 PM   #22
Darin P-B is offline Darin P-B  United Kingdom
I got the amp off my uncle, but apparently it worked well when he used it last (3 years ago).
Have put the amp into a shop to get repaired - as not overly confidant that I wouldn't solder the surrounding components together when replacing the transistors.
When I get it back is there any special way everything should be connected? To avoid blowing anything else?
There seems to be only one output for the speakers but my Linn Kaber LS500's have 3 left and right inputs and can be bi/tri and single wired/amped by means of shifting some plates. I only have the one amp though, so does this mean I just single wire them ie one plate over all three left and the other over all three right at each speaker?
Thanks again for all the help and advice
Darin
Old 24th May 2004, 09:50 PM   #23
Did it Himself
If it was working fine when you were given it then I think you may have damaged it by putting the amp unit fuses in I am surprised though that this did anything to the output stage, most likely it would damage the PSU capacitors and/or rectifier diodes.
To bi- or tri-wire your speakers all you need to do is join all 2/3 wires into one 4mm banana plug at the amp end. Then remove the plates on the speaker and wire the separate connections.
Old 24th May 2004, 10:00 PM   #24
Is that not the same as running just the one set of wires and using the plates?
Old 24th May 2004, 10:02 PM   #25
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Hi Darin,
I haven't red the thread very carefully but do you use slow blowing fuses marked with a "T"?
I guess you have glass tube fuses?
Old 24th May 2004, 11:02 PM   #26
Did it Himself
The Cyrus amp requires fast blow (marked F) type fuses.
LOL don't let any bi-wire advocates read that What did you think bi-wiring was, then?
Old 5th June 2004, 03:09 PM   #27
It would seem that I do not fully understand this single/bi & tri wiring.
My amp only has one set of red and black outputs for each of the left and right speakers. The Kabers have 3 sets of red and black inputs per speaker.
So from this info can I bi and tri wire with what I have? (obviously I would need more cable). If so are you saying that removing the plates and running three separate sets of wires for a speaker back into the amp ie 3 cables going into each banna plug - that I will improve the sound? It seems the same as having the plates on and running just the one set of wires as everything is connected to each other anyway.
Must remind you that I am an amatuer to all this so what may seem obvious to you is not for me.
I have recieved the Cyrus units back and its all go. The cyrus/kaber combination produces an awesome sound - I'm very impressed.
Thanks again for all the advice
Old 6th June 2004, 09:07 PM   #28
One other query you may be able to help with -
When the Cyrus II and the Cyrus PSX units are conected and music is coming from the speakers, if I switch both units off the sound fades after about 30 seconds. If I switch only one or the other off the music still stays the same (as long as any one of the units power switch is on). And most bizzare when I switch off and disconnect the Cyrus PSX unit completely there is no difference.
This makes absolutely no sense to me, can you explain why and what the Cyrus PSX does or is supposed to do.
Cheers
Darin
Old 6th June 2004, 09:16 PM   #29
Geoff is offline Geoff  United Kingdom
Yes, I can and will do so in a reply to your separate email.
Old 7th June 2004, 06:36 PM   #30
Did it Himself
Indeed, you can bi- or tri-wire just with what you have, plus more cable. I'm not saying it will improve the sound, some people claim it makes a difference, that's all. Note that what you may percieve as differences to the sound by bi- or tri-wiring may actually be down to the simple fact that you have more cable capacity going to the speaker. To confirm this, leave all the cables connected and put the shorting plates on again.
Regarding the PSX, the main amp power switch is redundant when the PSX is connected. The PSX just substitues a more beefy power supply than the main amp one.
Why are these fuses blowingHide this!Advertise here!
Keep Blowing Fuses Whiting Tubes / Valves 9 11th September 2008 10:44 PM
Car Amp help? Fuses blowing... Tolo Car Audio 1 3rd December 2007 02:42 PM
Blowing fuses balance Tubes / Valves 2 5th March 2005 03:16 AM
blowing fuses homegrown45167 Car Audio 2 22nd October 2004 01:16 PM
The Fuses Just Keep Blowing raffir Chip Amps 19 22nd June 2003 04:49 AM
Copyright ©1999-2017 diyAudio
