is there anywhere I can get a list of all the transistors avalble and there specs
#2 |
Banned
at the manufacturers homepage
#3 |
Towers' International Transistor Selector is a very useful book...
James |
#4 |
You probably want to consider which companies you might
consider buying from and then check what they have. There are zillions of transistors that are very difficult for most people to get their hands on without a big company behind you. |
#5 |
I'm looking for a list so I can look up what type of transistors I can use in a big amp I can only buy mj15003's here and I need to know what else I can use out of other equipment and surplus sales.eg I found the caps in an old motor starter 640uf 340v x80
#6 |
I have some information:
Motorola Trs 300K Power Units 320K Zetec Trs 125K Fairchild units 700K Sanken...too big, more than 3M Toshiba catalogue 1M But never used, if you want some i can send it to you... they are all in internet. but not so easy to find them. I do not know you an expert of beginner... this way i will tell you as a beginner. Buy those units: Low power to differencial input audio: BC547/557 BC546/556 BC639/640 Second stage: BD139/140 or MJE340/350 (can do the same work) Small power output and hy power driver units: TIP41/42 (for output 30 Watts RMS) or good driver. For Good output amplifiers: TIP35/36 (not sure, but around 80 watts amps) When 100 Watts darlington is needed: TIP142/147 Driver to use when needed hi quality: Mj15030/Mj15031 When hi power is needed: MJ15003/15004 (check it) When monster amplifier will be constructed: Some pair or , 2SC2922/2SA1216 This way, if you have those, you construct everything in audio amplifiers.... of course, can use many others, preferences, price, how difficult to find one and other...but you may have your own list, and type models in internet to have PDF data sheet for those units you will really use. Transistors is always the same, and always different, it depends on size, voltage, current, frequency and gain.... respecting that needs no one will explode. Some people say this sound better than those.... i could not perceive those small differences.... i am old, maybe no hearing so good. (not ironic, just a conclusion) Carlos
Try to build an amplifier folks ... it is pure adrenaline! |
#7 | |
It looks like you're in NZ, so you might find the following useful.: Retail Stores - a limited selection of transistors Jaycar Electronics - Jaycar Dick Smith - DSE Both of these also do mail order. Electronics Suppliers - a much better selection RS Electronics - RS Farnell Electronics - Farnell Hope this helps, SteveM |
#8 |
yes I am a beginner. yes I would like to get some of your catalogue files off you destroyer X my large file emal is wonder_b@slingshot.co.nz (20mb)
I am looking to build amp man's 800w 94vrails amp as a 600 (8ohm) 1150w(4ohm) 115vrails amp using around 8 output devices each rail incl cf diode and resistors .do you think this amp will work ok . I am most likely going to get a box of 100 mj15024's from the us if I cant find anything else they are around $5 each nz landed I have found them here thank you for the links black dog. but they want around $17 + post each for them (to much!!!!!!) If you are in nz and looking for some mj150024's email me. I am going to use 8x 12" 8ohm drivers per side on this amp $59 each from surplustrunics (.co.nz)in auckland I have 4 x10" now and they pump. Also can anyone help I have a 200w x3 ( dick smith eti480 tweeked) it runs fine on the comp but when i plug it into the tv(panasonic 21") it makes a very loud buzz (50-100hz) whats up can you tell me |
#9 |
My "turtle" telephone line system runs at 3.7 Kilobauds per second, and i can send those catalogues slowly to you... one each day. I will do it.
Will start in a matter of 15 hours... every 24 hours period at same time till finish. No problems, i will do it happy! Cannot say if your amplifier will run with good sound. But i will simulate it in Multisim, but those simulators do everything, but cannot say if sounds good or not. All assembly i done, with the same transistors showed in schematics, or also with different ones, i had always to change a little something... sometimes bias is hard to adjust... sometimes one of the transistors shows low VBE, something around 498 mV, and sometimes appear someone with to high VBE, around 689mV and i start to change some resistor value here or there. Also i always increase input Condenser value, always i reduce coil output value, always i increase all line filter condenser and put 100n capacitor in parallel with those condensers, because condenser internal construction is alike a coil, so, have inductance too.... a parallel 100n capacitor will let oscilations, or RF picked on wires flow direct and easy into earth ground. As i construct and test at least 12 amplifiers each month, and in those 40 years i could find only two that i really like the sound, i am very skilled related how to control frustration and not to destroy 30 percent of the assembling because work bad or measure bad or sound bad.... amplifiers can measure good and sound awfull, also can measure bad and sounds good, complicated ones normally sounds bad, simple ones normally sounds better... each component distorts a little bit, so, better to have one transistor (impossible in pratical life) doing whole job. Finishing assembling and connect and work since first time happens really, not more than 10 percent of the ones i have done... i made some thousands of amplifiers in my life.... 60 percent i could hear, 30 percent are completely awfull, and 10 percent can be usefull. Wonder, if you think a little you will see that i do not like "normal" sound... i prefer some special kind of harmonic distortion that looks more natural to me. My idea, best wide world amplifier, no doubts, Death of Zen, from Mr. Rodd Elliot, ESP, in Australia.... others.... i am sorry. I never keep amplifiers assembled...no place enougth and when doing for testing i do not matter if pretty or not.... must work with good sound... that's some brazilian people are.... people do not need to be pretty, and also do not need to be rich, do not need to be clever, have to be kind, have to be friendly and stay together us alike a dog does... this way, pretty amplifiers do not tell me nothing more than a good looking pleasure that stays in my heart for seconds..... good sound will make you dream for ever. Sometimes i use transistors that i obtain in 1970... normally i do not buy in shops.... i use to dismount Japanese old models that we bougth here for 10 dollares or less than that.... full of power transistors an whole filters and transformers.... very difficult to go out to buy some...only boards and solder. I will put an amplifier that is very strong and you can assemble without afraid... this one i can guarantee.... others not. This one sounds good, but loose power in deep bass.... but is so strong that you can reduce treble and put it to shake your neighborhood. Carlos
#10 |
A Brazilian factory already closed.... this is the lower powered from all them.
Can increase voltage to 70 volts plus and minus.... and use TIP41/TIP42 in the output, you will find three units in darlington conection, emitter to base and colectors together..... first and second may be those TIPs.... or the MJ all the people likes to put in their schematics.. do not use BD139/140 because voltage is too high, also do not use their cousin MJE340/350 too. All others transistors must be something alike BC546/556, look into their maximum VCE (Volts from colector to emitter) if can be usefull.... better when they are twice the voltage used in plus, or twice the voltage used in minus rails. In the output use your power MJ transistor.... if they are the ones for output power.... the ones that can work with more than 10 amperes and voltage more than 150 volts. Put 4 pairs and enormous heat sink and take the bigger transformer you can find... one transformer for each channell, also, at least, minimum 20000 uF each voltage rail electrolitic condensers for filtering.... if more will be better.... big bridge rectifier units, one for each transformer and prepare yourself to receive a punch of bass in your stomach. Carlos
| DAC List | KBK | Digital Line Level | 16 | 5th May 2009 02:40 PM |
| Wanted your help for a list of transistors | mcmahon48 | Solid State | 3 | 20th February 2009 09:26 PM |
| Esl To Do List | bshaw147 | Planars & Exotics | 0 | 6th September 2008 05:10 PM |
| dac list | Günter H. | Digital Source | 1 | 11th September 2003 01:30 AM |
| Page generated in 0.13228 seconds (83.25% PHP - 16.75% MySQL) with 11 queries |
