Old 22nd May 2004, 05:13 PM   #11
bellx is offline bellx  South Africa
Send a message via AIM to bellx Send a message via MSN to bellx Send a message via Yahoo to bellx
Default Substitution
What can be substituted for the TC7WH04FU, TC7WH08FU and LT1220CS8 in th IRF circuit?
I need more power!
Old 13th June 2004, 03:43 PM   #12
THE CIRCUITS TC7WH04FU, TC7WH08FU,IR2011 CAN REPLACE BY THIS?
Old 13th June 2004, 07:20 PM   #13
Default looks simple enough
I have built a prototype of my own class D amp, works very well with just 2 fets but I'm having problems with paralleling more fets, it gets unstable. Mean while I shall try this self oscillating design.
I need more power!
Old 14th June 2004, 09:49 AM   #14
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
has anyone had any luck downloading that book at
http://doc.utwente.nl/fid/1351 ??
I get the first page and then it just hangs.
Thanks,
Chris
Old 14th June 2004, 12:40 PM   #15
HI bellx
I think you confused with class-AB & class-D amplifier,Is you
need more power you must increased voltage, one pair mosfet is
enough to drive up to 1 kw on half bridge configuration,so now I just
strat my class-D amplifier project,voltage +/- 130-150v ,mosfet use
irf450 ,power supply user ETD 49 CORE with ir2153 self oscillation
driver can up to 400W /4 ohm,but power supply design is not completed
Old 14th June 2004, 01:20 PM   #16
Account Disabled
Originally posted by GEORGE HO
HI bellx
IRF450.....500V, 13 amps? RdsOnb .4ohms....seems kind of high..if you doubled them up...you could have 26 amps.... 0.2ohms...which still seems high, but there is at least a reason for doing it.
Bit harder to drive though.
I think the prefered solution seems to be, find a better mosfet, which can be a real pain, but in the end the payoff is large.
Your amp sounds interesting...I'd like to know how that controller works for you.
Good luck,
Chris
Old 15th June 2004, 06:10 PM   #17
Steven is offline Steven  Netherlands
Steven's Avatar
Thanks,
Chris
No problem at all. Just tried again and received all 128 pages.
Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973
Old 15th June 2004, 06:33 PM   #18
Account Disabled
Hi Steven,
I'm still unable to download it today...same thing I get the first page and it hangs, not a problem I usually have.
It's alright though I had a friend try the link out and he was able to download it for me and sent it over.
Thanks for the link it's a great read.
Chris
Old 15th June 2004, 07:12 PM   #19
Steven's Avatar
You're welcome.
Steven
Old 16th June 2004, 11:12 PM   #20
HI Chris
http://doc.utwente.nl/fid/1351 ?? This page tried to save on
disk,do not open it .
GEORGE HO
Can someone tell me how this works? keantoken Solid State 17 22nd May 2009 03:43 PM
How this circuit works (Baby Huey type) rockgardenlove Tubes / Valves 13 15th November 2008 03:08 PM
if this can works... Stee Tubes / Valves 4 12th January 2008 07:37 PM
It works .... jcayer Pass Labs 3 28th February 2005 01:00 AM
Copyright ©1999-2013 diyAudio
