Old 15th May 2004, 10:05 PM   #11
johnnyx is offline johnnyx  United Kingdom
This kind of circuit senses the ac voltage from the power transformer independantly of the main reservoir caps. It will probably use a large series resistor and cap to give the 2 sec delay. there will probably be a diode in reverse to discharge this cap quickly when switched off. I don't know the actual circuit, but they all provide the same function. The time constant is chosen so that it will give a steady output voltage, and hence relay switched on, during the 10mS pulses from the transformer.
time = 1/f = 1/100Hz = 10mS
If the time constant is say 12ms, then the output will be steady. When the power is switched off, the relay switches off after 12mS.
If the fault reduces the time constant to say 5mS, then the relay will see pulses instead of a steady voltage, causing relay chatter.
There are many ways to achieve this. there may be two seperate timing devices, one for turn on delay, the other for turn off delay.
Try to identify and change the components in this circuit.
Krell might use a tricky-dicky circuit, just because it's Krell.
Hope this helps.
Old 15th May 2004, 10:20 PM   #12
K-amps is offline K-amps  United States
K-amps's Avatar
Thanks Echo and Johnny,
Looks like I will need to spend more time than I thought initially.... I just hope there are no custom IC's ... I suck with IC's
Old 1st February 2012, 01:01 PM   #13
Relay hugobors Parts 6 21st February 2006 10:20 AM
Looking for the best relay carlmart Solid State 15 19th August 2005 12:06 AM
Can I use a SIL relay ? Ryssen Solid State 8 29th December 2003 10:45 PM
Help with relay ppereira Solid State 14 21st June 2003 08:10 AM
Relay or not relay ? Yonnat Pass Labs 10 10th April 2003 07:26 PM
Page generated in 0.08465 seconds (73.09% PHP - 26.91% MySQL) with 10 queries
