Old 13th May 2004, 11:45 PM   #1
Tensop is offline Tensop  Lebanon
Default a few pics of my amp
hey, finally got hold of a (crappy) kodak dc3400 digicam.. the amp is an sc480 kitamp from jaycar in vic.. specs are 0.03%THD @ 50w/8r
psu consists of 150va, 9400uF capacitance per amp, so 20,000uF and 300va in total.. sounds very nice but a bit weak in the low end
Old 13th May 2004, 11:48 PM   #2
Old 14th May 2004, 05:33 AM   #3
li_gangyi's Avatar
wonderful job...wonder why it's weak on the low end...might be due to the input cap?
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 14th May 2004, 06:26 AM   #4
Doubt its due to the capacitors, the roll off chart is only about -2dB @ 10hz
and my mistake - its actually 9400uF per rail(10,000uF when taking the pcb mounted parallel cap) so 40,000uF all up. the low frequencies are extremely clear, best i've heard from an amp yet but a bit too quiet. when i get the time i'll clean up the wiring and use some shielded inputs to the amp, to get rid of the slight high frequency interference im getting, maybe put a grounded shield around the transformers to isolate them too?
and, as a great source for mains cables i took the powersupply cable from an old AT computer case, it has an earth shield all through the inside(foil and braided wire), even had an earth lug on the end!
Pinoy DiY'ers, FT1600 pics..pics dranreb&* Full Range 5 3rd November 2004 10:21 PM
Pics of my new amp Cro maniac Chip Amps 19 8th May 2004 04:20 PM
Pics of my new amp! Morse Tubes / Valves 16 21st April 2003 07:04 PM
PICS: GainClone Monoblock pics Rarkov Chip Amps 19 17th April 2003 07:37 AM
Page generated in 0.09876 seconds (58.22% PHP - 41.78% MySQL) with 10 queries
