Old 12th May 2004, 08:58 PM   #1
Wagener is offline Wagener  South Africa
Default why a cermet pot?
I can't seem to find a 2k cermet pot used in the leach amp. I suppose this is only for quality. Will a normal cheap pot do the job as well?
Also I can't find stacked metal film capacitors. I will be using polyester capacitors instead. Comments will be appreaciated
Old 12th May 2004, 09:25 PM   #2
Send a message via AIM to jewilson
A condutive plastic pot would be much better that a cermet one.
Jim W.
Old 12th May 2004, 09:40 PM   #3
diyAudio Retiree
Default Sez you...........
"A condutive plastic pot would be much better that a cermet one." - JW
Unless you care what it sounds like........ the cermets sound noticably better. I replaced my ALPS 100K Black Beauty with linear cermets with Caddock resistors from wiper to ground for a law faking taper. There's no comparison. The Alps sounds colored, soft, rolled off, and doesn't have the detail ....... and they cost a bunch. It is complementary to slightly hard and bright electronics. The TKDs are the best conductive plastic ones I have heard but have a different "log" taper and aren't cheap either.
Old 12th May 2004, 10:02 PM   #4
Fred,
If cermet pot might be ok as a trimpot in a bias circuit. You should run a HF square wave through one and tell what you don't see.
How the head.
Jim W.
Old 12th May 2004, 10:19 PM   #5
Banned
you are all wrong the best sound ever from a pot i have from this one:
Old 12th May 2004, 10:25 PM   #6
Till,
You win, that is the strangest looking pot I have ever seen and it's power with a car battery. Does it run in class A.
Jim W.
Old 12th May 2004, 10:46 PM   #7
Default Re: Stacked caps
Both Panasoninc (type V) and Epcos make stacked polyester caps, B3252X.
Epcos also makes stacked polypropolene caps. B32620/1
All the above radial caps are available from Digikey.com in the States. Outside of N.A. I'm unsure, but assume the Epcos are readily available in Europe.
Old 12th May 2004, 10:50 PM   #8
The pot described in this thread is not the type intended for
smoking
Old 13th May 2004, 12:07 AM   #9
diyAudio Senior Member
fdegrove's Avatar
Sure...Epcos is a Siemens spin off after all.
EPCOS DEUTSCHLAND
MKP/MFP CAPS
Frank
Old 13th May 2004, 02:43 AM   #10
sam9 is offline sam9  United States
sam9's Avatar
If the pot is being used to adjust the bias, Im not sure the signal passed through it anyway. I this is the case, the "sound" is notparticularly inportant but the stability (wrto age, temperature, etc). Also if it's small trim pot, some have a limited number of end-to-end rotations (or so the datasheets say) so there is only so much fiddling with the bias you can do before possible mechanical failure. I don't know if cermet, plasic or whatever suits this use best but perhaps another poster has some info on that.
WTB sealed cermet 50K dual gang audio Prune Swap Meet 2 28th May 2004 08:19 PM
Cermet preset Ned Chip Amps 0 21st February 2004 07:12 PM
100K linear cermet pots HarryHaller Swap Meet 0 19th September 2002 07:18 PM
Page generated in 0.10961 seconds (75.92% PHP - 24.08% MySQL) with 11 queries
