I have one trafo with two secondary windings feeding four rectifier bridges for two symmetrical regulated powersupplies like shown in sketch below. Something is wrong with this circuit because it trips the main fuses of any value. I also tried bare wire soldered across the fuse for a second (WARING- don’t try that at home) and seems like there’s a short circuit somewhere because tranny and bridges got really hot during that. Only thing I can figure out is maybe short in the capacitors. But the caps were fine before applying power. So I am clueless. Can somebody figure out what is wrong here?
Thanks in advance Argo |
#2 | |
secondaries are shortened with two serial two antiparallel diodes thru ground. Two bridges for same supply must be supply from same secondary. For example, B1 and B3 from S2, and B2 and B4 from S1. Regards |
#3 |
Oh yeah, I must have been blind I just draw the sketch only after I wired the circuit. I wired it like this because it was more convenient (shorter wires, less mess). Very stupid of me
I should have drawn the circuit before wiring and give a second or two of thought rather than second or two of shortened secondaries Thanks a bunch for pointing out this error Argo |
#4 |
Also, this PS setup isn't optimal, IMHO. A better setup is with CT secondary and single bridge for each +/- PS. Regards |
#5 |
Why this setup isn not optimal?
I wold agree two trannys instead one would be much better. This is my final goal but did'nt had two of them at hand so I tried with one at first. |
#6 | |
draw bridges like 4 diodes. Than you will find that you have parallel diodes pairs from different bridges thru the ground point. If those diodes haven't perfectly same V-I characteristic some current will flow thru ground connections from first to second PS and vice versa. This isn't good. Regards |
#7 | |
I see . Good point Thanks. Argo |
| little 6.5 mystery ... | oface | Full Range | 6 | 4th November 2007 11:20 PM |
| Powersuply Le Bong? | HDaudio | Tubes / Valves | 11 | 14th February 2007 11:10 PM |
| 2 trannies on one powersuply | Per | Solid State | 15 | 10th October 2002 06:42 AM |
| Page generated in 0.09772 seconds (74.59% PHP - 25.41% MySQL) with 11 queries |
