I need a small wattage class-A transistor amplifier (even 3W will do). Anyone has the schematic to share?
#2 |
Isn't the oiriginal Pass DIY Zen class A amp 5W/ch? Do you have to have 4W or 3W?
#3 |
You can always use an AB polarized for 4W in output class A and the rest in AB. Is not much too heat, and you'll use it most of the time with A, and a respectable headroom.
What is beyond the speaker? |
#4 |
Downsizing a Zen or any other Pass project should be a breeze.
I have a pair of Mini a monoblocks that doesnīt give more than maybe 5 or 6 watts, a friend offered me some hard cash for them after he had heard them in his system |
#5 | |
So now you know why I want 4W. I have lived with 2.5W and I just wanted more. The Zen seems to use big heatsink, but I will look again. Hey Fuling, would you share the schematic? |
#6 |
Banned
For 4W Zen heatsink would not be too big, and for Zen lite most heat is in the lightbulbs so you could even use smaller heatsinks for transistor.
http://www.passdiy.com/projects/zenlite1.htm |
#7 |
Account Disabled
you can always use a jlh for that. maybe at lower voltage.
If that's too complicated, you can always use a SE amp for that but it may dissipate more heat. |
#8 | |
I use IRFP460īs and 2x10V 50VA transformers simply because that was what I had at home. |
#9 | |
what's the efficiency of the jlh? |
#10 |
I built the Son Of Zen with + and _ 12v rails (well a set of 12 v batterys) and with my speakers that didn`t need a high damping
factor it sounded marvious. Thanks again Mr. Pass. Woody |
| 1500W RMS Class D PCB - which Class D Driver Chip is it ? | mosfetsound | Class D | 11 | 1st April 2011 11:17 AM |
| Can a Class AB PP amp be said to be operating in Class A at low signal levels? | ray_moth | Tubes / Valves | 19 | 23rd January 2009 07:52 PM |
| How about a round-up of Class A kit power amps, or collectable vintage class A? | Brisso57 | Solid State | 4 | 14th February 2007 10:30 AM |
| Page generated in 0.09594 seconds (74.73% PHP - 25.27% MySQL) with 10 queries |
