which capacitors to use in leach???
Old 5th May 2004, 04:15 PM   #1
Wagener is offline Wagener  South Africa
Default which capacitors to use in leach???
I still haven't found a substitute for the mica capacitors.
I can obtain the following types of caps:
Multilayer Ceramic - Through-hole Capacitors
Polycarbonate Capacitors
Polyester Capacitors
Polyphenylene Sulphide Capacitors
Polypropylene Capacitors
Polystyrene Capacitors
Precision Polypropylene Capacitors
Silvered Mica Capacitors
Solid Tantalum Capacitors
Which of them would be best suited in leach amplifier in place of mica (10pF, 47pF, 390pF)
Old 5th May 2004, 05:10 PM   #2
pooge is offline pooge  United States
silvered mica are mica caps. Will probably be the only ones you can find at 10pf. Polystyrene for all of those values would be excellent choice, if you can get them.
which capacitors to use in leach???Hide this!Advertise here!
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 03:15 PM
Leach bipolar capacitors pinco Solid State 20 13th June 2008 11:06 AM
Leach Amp PSU Capacitors adrianbodor Solid State 2 23rd November 2004 11:37 AM
resistors and capacitors in leach amp Wagener Solid State 3 30th April 2004 11:42 PM
Capacitors for the Leach ? Flavius Solid State 3 2nd June 2003 10:07 AM
Copyright ©1999-2017 diyAudio
