I have an old Kenwood KA-88 amplifier...
It works fine...I just wanted to know the specifications of it? I can't find them anywhere...i even went to the kenwood site.. And I wanted to know if there's any way I can modify it for better |
#2 |
no one?
#3 |
All I know is that it is rated at 100WPC. And I'm sure there's lots you can do to it...get the manual and look it over.
#4 |
Dividing the power consumption by two, you will have an idea off the greatest power the amplifier will produce...only one idea.
This power will be in the lower impedance it can works, and this is written outside. Some new amplifiers can go to 70 percent efficiency... 30 percent off heat and 70 percent of power. I will be, maybe, trying to say something you already know very well...but i do not know you to measure your knowledge, this way; 200 watts consumption will be something around 100 watts audio, 50 watts each channel in 4 ohms.... a little bit more than a 25 watts rams each channel in 8 ohms speakers. If 70 percent you can calculate because is too much easy. I will find more informs...i know i have something alike kenwood 80, will search it for you. Carlos
Try to build an amplifier folks ... it is pure adrenaline! |
#5 |
All them rated lower power than they really are capable to produce.
They are rated at very low distortion.... this way a 35 unit will put twice this power in the speakers. But dividing consumption will give good results.... 45 percent audio only...maybe a lot of lamps and other consumption circuits. I have in my hands: Kenwood KA-32 Kenwood KA-35 kenwood KA-89 Kenwood KA-100 Kenwood KA-400 Kenwood KA-910 If you want some of them i can send schematics directly to you mail. They are underrated all them.... your model may give 40 plus 40 RMS/4 ohms, and maybe 30 plus 20 watts rms/8 ohms or something alike.... it will be rated at 20 plus 20 and the consumption will be 100 watts. Carlos
#6 |
I found Kenwood KA89 integrated amplifier in:
"www.schematicsforfree.com" "audio amplifiers" "integrated" Can be helpfull. Carlos
#7 | |
I have owned and used my KA-88 since 1985 and still have the original manual for it. At the top of my head head it's a 100 WPC, class A amp resp 20 -20Khz at 0.01 THD (I might be wrong about the THD figure). I hope this helps. |
#8 |
Account Disabled
Carlos...check your mail...please..
| kenwood kac-715 | purocolt | Car Audio | 5 | 4th September 2007 01:54 PM |
| Kenwood L-07D... | bulgin | Analogue Source | 0 | 14th July 2007 07:18 PM |
| Which dac has this Kenwood? | tubee | Digital Source | 5 | 22nd August 2006 07:34 PM |
| kenwood vr 309 | v1d9uy | Subwoofers | 0 | 8th January 2006 01:48 PM |
| Kenwood KR-750 | Brian Donaldson | Solid State | 0 | 13th April 2005 02:44 AM |
| Page generated in 0.09436 seconds (73.05% PHP - 26.95% MySQL) with 10 queries |
