2 x 750va toroids sufficient for leach?
Old 2nd May 2004, 02:00 PM   #1
Wagener is offline Wagener  South Africa
Default 2 x 750va toroids sufficient for leach?
I am building my power supply for a 4 channel leach amp. I can get 2 x 750va toroids with 40-0-40 secondary for a good price. Will this be enough power? - i will use the leach amp to run 4-ohm loads.
Old 2nd May 2004, 02:14 PM   #2
JensRasmussen is offline JensRasmussen  Denmark
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Hello,
I'm runnig my Leach at 2x40 V AC using 2*500 VA for four channels into 6 ohm loads....no problem at all. I think you will be fine.
\Jens
2 x 750va toroids sufficient for leach?Hide this!Advertise here!
FS Pair of Plitron 750VA,dual 30V Transformers Algar_emi Swap Meet 0 24th January 2009 12:38 AM
750VA Torid 120V/55V+55V amelecsol2000 Power Supplies 7 1st June 2006 11:09 PM
Sufficient power for the Fountek JP-2.0? mazeroth Multi-Way 3 20th April 2005 03:37 AM
Is 12dB/octave sufficient for subwoofer? skyraider Subwoofers 13 27th February 2005 03:21 PM
Is the 1.1A diode sufficient? w00t Chip Amps 2 16th August 2004 05:52 PM
Copyright ©1999-2017 diyAudio
