Subwoofer Plate Amp Crossover Not Working
Old 28th April 2004, 03:37 PM   #1
Monroe is offline Monroe  Canada
Default Subwoofer Plate Amp Crossover Not Working
I just received a sub-100 (150 watt into 4 ohm) subwoofer plate amp from solen.
It seems to work ok, except for the crossover - with either high level or rca inputs, i get quite a bit of vocals/high freq. stuff coming through. Much too much for my taste - it doenst seem like the crossover is doing much.
Is this normal for cheap plate amps? What's up here? Is something miswired? (I take it that the crossover is not only supposed to remove the low end for the main speakers but also the high end for the built in sub amp...)
I suppose I will have to send it back, unless its an obvious fix.
Subwoofer Plate Amp Crossover Not WorkingHide this!Advertise here!
working out Z out for tube with IXYS IXP10M45S plate load duderduderini Tubes / Valves 9 18th January 2008 07:13 AM
Non-plate subwoofer amp? hofffam Subwoofers 17 27th January 2005 05:45 AM
Subwoofer with a working drawer? Timn8ter Subwoofers 4 7th January 2004 08:24 PM
Subwoofer Plate Amplifier Base Plate supplier? jwells777 Parts 1 11th May 2003 07:40 AM
Copyright ©1999-2017 diyAudio
