#2 |
While there's not quite enough information on your schematic to make a real "design review",
Seriously, you must consider that the On Semi transistors are fairly wideband, and in my experience, using them in the circuit you have shown "Exactly as drawn" could be problematic, because there are no base stopper resistors or other methods for controlling local oscillation. Wideband amplifiers can change into high frequency oscillators under a variety of conditions. I'd expect any of the faster extended beta Sanken's to behave the same way, as well as the Toshiba's. Is this a published design with a PCB layout? Capacitor coupled output, too? Not the best way to go; check Douglas Self's book about the details regarding output capacitor LF distortion. If you are enamored of the possibility of a vacuum tube plus solid state amp you can build, Hawk Audio in NL has a nice kit with a vacuum tube front end, MOSFET output stage, and direct coupled at the outputs. Also, it is a non loop feedback design. Regards, Jon |
#3 |
#4 |
#5 |
There is no DC reference for the output stage, the output DC is undefined. So, unless you somehow ground-reference the SS part like with resistors from Q1, Q2 base to ground, your speaker will be short lived.
Jan Didden |
#6 |
The amp Daniele is referring to is the GY-50 by Bartolomeo Aloia, who is a very good designer.
This is a project I could have been interested into, if I hadn't bought a bunch of Mullard ECC88s I think that the MJL3281/1302 can be just fine (better MJL4381 and 4302), check the SOA if you plan to use them on tough loads. The drivers can be the 15030/31 (or the more recent 15033/34).. after all it is, IIRC, a 50W amp.... Cheers Andrea PS Daniele, where do you buy the HT trafos? Edit: the amp is made for single supply, so don't modify it unless you really know what you're doing! |
#7 | |
The amplifiers is for car use! The power supply is a SMPS. |
#8 | |
#9 |
all the resistances that I will use are to 1% and all the transistors will be select to
#10 |
I'd use an extra output pair just for the extra headroom.
The drivers you suggest are good too. |
| Need amp repair help - Can you ID this semiconductor? | GaryM | Solid State | 13 | 21st February 2008 01:10 PM |
| search for old ic, semiconductor | bluesman52 | Solid State | 1 | 20th January 2007 04:07 AM |
| motorola vs on semiconductor | Wagener | Solid State | 3 | 23rd May 2004 03:21 AM |
| Good semiconductor distributor. | JoeBob | Parts | 1 | 18th January 2002 03:16 PM |
| Page generated in 0.11957 seconds (81.31% PHP - 18.69% MySQL) with 10 queries |
