inrush current
inrush current
Old 3rd September 2007, 08:22 PM   #21
aandy is offline aandy  United Kingdom
the tools to make EI's are a tool for spinning a bobin eg motor lathe and a counter and you can do this by hand as well keeping count.
so any one can do the EI's
the toridal needs 30k usd off tools, magazens and tape heads, gear heads.
there is no cheap option.
andy
sed me your email
i can send you some pics
Old 3rd September 2007, 08:26 PM   #22
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
inrush current
I use big UI core, have you tried those, should work in a similar way like c-core, with seperate coils
Old 3rd September 2007, 08:42 PM   #23
anatech is offline anatech  Canada
anatech's Avatar
inrush current
Hi Andy,
the carver amp uses a c core tx in near saturation mode,
Yes, this was the staple power supply for most of their amps. What ever he did, those "transformers" would draw excessive current with a sine wave input. We got many ordered by technicians that we wouldn't take back (after warning them first). I ran the Canadian factory warranty service center and parts depot.
this is not a high frequency power supply,but uses a triac as a light dimmer!
True, I was including the PM 2.0 which is a switcher, around 2 KHz I think it was.
As far as the light dimmer is concerned - a gross simplification. The on time had to be carefully balanced. By the time the M1.0 came out he had that licked. Before that time, the triacs would fire inconsistently at no low. This produced a "ticking" sound.
The last design used a regular EI transformer that created high rails of 125 VDC each. This was reduced by a high frequency switching "down converter" that simply varied the duty cycle. Very nicely done too!
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 3rd September 2007, 08:51 PM   #24
anatech's Avatar
inrush current
Hi Andy,
i am working on hipower smps at the moment for my amplifiers.
Eva seems to be very well versed in these also. She certainly knows her stuff. This type of design makes far more sense at high power levels.
I can understand that for sure. Even the winding for EI types should use more than a drill and counter.
i have also managed a winding dept for EI txs 18years ago.
Now that is nifty! My interests and knowledge run more to analog circuits. You are way beyond my skill level here. I just sniff for that unmistakable burnt - sweet smell. You know the one.
sed me your email
Sure, bhomester at gmail dot com. Thank you.
it is quite likely you have had junk toridals, there are a lot about.
I am afraid that you are probably correct there. Manufactures of consumer gear normally do not use the best parts available. I would normally turn to Hammond or <forgot the other one> as they are both located in Ontario where I live. I actually did get to meet Fred Hammond before he died. He was a super guy, very helpful.
-Chris
Old 3rd September 2007, 08:54 PM   #25
I am currently re doing my 3kw H class amp.
with smps would like to do down converter but time is to valuble to me.
have you worked on the crest amps?
andy
Old 3rd September 2007, 08:57 PM   #26
anatech's Avatar
inrush current
Hi Andy,
Yes, but I sold my company about 10 years ago. So I haven't seen one for a long time now. I had more fun with lower powered good consumer amplifiers.
-Chris
Old 3rd September 2007, 09:02 PM   #27
Have you heard of Bowers and Wilkins loud speakers and Aura where you are?
andy
Old 3rd September 2007, 11:04 PM   #28
fotios is offline fotios  Greece
fotios's Avatar
Sorry for my intervention in this battle of Titans. In Greece there are 2 very serious workshops of transformer construction. The first be found in Thessalonika and made only EI transformers in verry high prices. The second be found in Athens and made only toroidal transformers in some lower prices. For toroidals i am a little reserved (because the solidity of their core depends on how much tight it is the winding of wires around the core and because the under layer of primary it is from thicker wire than the secondary then the strong tightening has some limit to not broken the primary wire) then i gave a special order as follows: 1) After the core formating and before the winding procces to dipped in enamel and left to dry. 2) During winding the wire dipped in enamel separatelly 3) Finally the whole construction fixed in a metal box with the use of epoxy resin. This extra work, it cost more 25euros per xformer. Finally when i deliver the xformer i left it in the shelf for 10 days to dry very well everything. Of course a such type xformer due to its metal case probably it has the most possible little electromagnetic radiation around it. Yet with so much care (i don't believe there is nothing furthermore of this) a verry little cracking of 50Hz heared from the core if you touch your ear on the case. Why this? Therefore it is worth the extra cost for a such type fortification of xformer?
I quote bellow a picture to view the construction
Fotios
Old 3rd September 2007, 11:29 PM   #29
anatech's Avatar
inrush current
Hi Andy,
Bowers and Wilkins yes, Aura no. Not unless the trade name is different here (eg. Crown and Amcron).
Hi Fotios,
No battle here. Also, you are not interrupting.
I am afraid we are straying from the main topic though. Comments on build quality of transformers are weakly on topic though.
-Chris
Old 5th September 2007, 06:14 AM   #30
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
The classic soft-start power resistors in aluminium case bypassed by a relay can cause a lot of trouble when the relay fails to close. They don't go open until the temperature is enough to cook everything around them.
Also, in order to be reliable, the resistor and relay approach requires the amplifier circuit to be muted and put in standby mode (no bias) until the relay closes. Furthermore, the control circuit must ensure that the relay closes even in low line conditions.
An alternative approach is to place one or more low value power NTCs in series and bypass them with a relay. When placed in the primary side, this gets rid of both transformer flux imbalance inrush and capacitor bank inrush. I find this way more reliable, and it results in lower cost and a more compact layout.
In general, I find most people in this forum very reluctanct to any new ideas, circuits or working principles not matching the common practices of the past 30 years. The fact that a circuit hasn't been used for the past 30 years doesn't make it a bad circuit.
I use to feel like the small child in The Emperor's New Clothes tale
inrush currentHide this!Advertise here!
Using Inrush Current Limiters hollowman Power Supplies 6 16th June 2012 09:27 PM
5Z4 inrush current too high Craig405 Tubes / Valves 10 3rd September 2007 07:58 PM
inrush current Jules Tubes / Valves 8 26th December 2003 05:38 AM
inrush current limiters colden Parts 9 17th October 2003 09:43 PM
About Inrush Current JDeV Parts 0 2nd December 2002 06:40 AM
