I'm trying to make a simple delayed on circuit for my headphone amp to prevent power-on thumps. RainerB on the headwize forums pointed me to the eaton amp which has the following slow-on circuit:
After much frustration about the relay not comming on i did a little testing, but before that i'll just say what is different: 1. The pot is 200kohm not 250k (right pin on +ve and wiper connected to the transistor base, the left pin touches nothing!) 2. i'm trying to power it from 12v not 24 3. i'm using a 2n2222A transistor not a 2n2222. 4. my capacitor is 470uf 16V not 35V Basically after much frustration about nothing happening on the output i measured the voltage accross the capacitor. This rises steadily like it should at about 0.15v / second, however that's when there is no transistor in the circuit. As soon as the transistor is placed in the circuit the capacitor begins to behave differently. It charges at the same rate but stops charging at 0.6v. It does this regardless of if the output is conected or not, it never sets of the transistor, and therefor never the relay. Different capacitor values and resistor values do nothing. I've tried the transistor around both ways to make sure it was connected right, but it behaves the same no matter what happens. I've only used transistors twice so far so i'm not sure if something is wrong can anybody give a bit of insite? |
#2 | |
Account Disabled
of course it will stop at 0.6v (Vbe for a silicon transistor), the said circuit will not work because of that. What you can do, however, is to place a resistor at the base of the transistor so it "isolates" the be junction of the transistor from the R/C charging portion of the circuit. |
#3 |
I don't see a protection diode. (This should be a diode across the relay pointing towards V+) You may have already destroyed your first transistor, check it if you can.
P.S. When using a pot as a variable resistor one usually connects the "free" side to the center. This is to avoid going open-circuit during adjustment. |
#4 | |
Do you have some sort of resistor in series with the coil? Is it to large? Is your coil a 12V coil? What is the C-E voltage after the cap charges up? If it's below about 200mV, then the transistor has done all it can do and the problem is not enough current to trip the relay. |
#5 |
Hi Garbz
If your relay is a 24 volts relay...it will not work with a 12 volts rail. Regards
Jorge |
#6 |
There are, however, 12V relays; probably on the same catalog page where you got the 24Ver.
#7 |
wow thanks for the speedy replies. I'm not used to this, on other forums a simple question can take days.
I've figured out hte problem it's because of the voltage drop across the transistor. I was using a 12v relay, and no I didn't destroy the transistors, and i always did use a protection diode. This schematic isn't mine. The transistor did acutaly work, but only forwarded 4.7v out of the 9.8v input it got. This was definatly not enough to throw it. The solution was a second transistor another 2n2222 connected.... not in parallel... but... basically emitter of one to the base of the other, and bind the two collectors together. The end result other than a 2 second increase in time it took since the capacitor needed to reach 1.2v, the forwarded voltage was about 9.5v which was enough to trip the relay. Thanks a lot for all the responses. My guess is that the original schematic at the top used a 12v relay on the 24v rails. A secont transistor was MUCH cheaper then buying another 5v relay |
#8 | |
Your original transistor just didn't have enough gain to do the job. |
#9 | |
6 times the capacitance and 1/6th the resistance will probably work better. Or use a Darlington transistor. This can be constructed from 2 Transistors. Google for the connection, it's standard. The Darlington switches at 2 * 600 mV, so you have to adjust the delay. A small N-MOSFET fits the bill, too. But then you have to limit the gate - GND voltage to something like 6V because otherwise the capacitor would charge all the way to 24V, not good for your 16V cap nor for the gate of the MOSFET. Somebody already mentioned the diode across the relay coil. If the relay switches OFF, the stored energy in the coil is transformed into a voltage spike that easily may kill the 2N2222. The diode offers a less destructive path for the spike. 1N4148 or 1n4001..4007 will do. regards, Gerhard |
#10 |
Electrons are yellow and more is better!
Garbz, you forgot a couple of things.
1 Calculate necessary base current, then you know the max potentiometer resistance. 2 Capacitor value. Remember that the cap will not get charged to supplyvoltage, only 0.6-0.7 votls and this will make a shorter charge time than usual. 3 Diode across the base resistor in order to discharge the cap. 4 Diode across the relay coil in order to protect the transistor. As inspiration you could check out my soft start. My goal there was to make a very short discharge time. http://home.swipnet.se/~w-50719/hifi/sst01 A really good tool is in fact to simulate. Download LTSpice from www.linear.com and do some breadboarding in the computer.
/Per-Anders (my first name) or P-A as my friends call me |
| Looking for a simple circuit | Skitch72 | Tubes / Valves | 19 | 12th August 2009 07:31 PM |
| HELP-- I need a simple 50W AMP circuit --- | MTO audio | Solid State | 5 | 9th August 2007 06:46 AM |
| Help me with simple circuit | valterdaw | Car Audio | 2 | 22nd August 2006 07:15 AM |
| Searching for simple circuit | gary f | Tubes / Valves | 8 | 12th September 2005 03:00 PM |
| Simple circuit problem | arnach | Solid State | 3 | 14th April 2001 05:52 AM |
| Page generated in 0.17354 seconds (65.46% PHP - 34.54% MySQL) with 11 queries |
