Old 24th April 2004, 10:38 PM   #1
Kal is offline Kal  Germany
Default ETALON-schematics?
Hello,
has somebody any schematics of Etalon Acoustics from Hungary?
Their Amps sound great - one league with Ayre, Pass, ML...
Thanx
Old 24th April 2004, 11:59 PM   #2
Send a message via ICQ to Highlander
I found this one here:
Old 25th April 2004, 09:05 AM   #3
Thank you!
Etalon seems to be quite uncommon and that is a pity, because their sound is very transparant, detailed AND MUSICAL!
Old 25th April 2004, 08:12 PM   #4
I've never heard of this design, but appears to be a zero-feedback front end connected to an error-correction type of output stage. Jam should be interested in this one....
Old 25th April 2004, 08:36 PM   #5
Steven is offline Steven  Netherlands
Steven's Avatar
Nice design, using Hawksford's error correction around the output stage. Some months ago, I thought there were not many amplifiers using this technique, but it seems they are just good sounding secrets .
For those who are interested in other designs using this technique (both with and without overall feedback):
http://www.diyaudio.com/forums/showt...446#post330446
http://www.diyaudio.com/forums/showt...997#post330997
http://wes.feec.vutbr.cz/~gratz/Download/Hawksford.ZIP
http://wes.feec.vutbr.cz/~gratz/Download/Cordell.ZIP
Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973
Old 25th April 2004, 08:44 PM   #6
Steven's Avatar
I'm a bit surprised though by the triac at the output of the Etalon amplifier. This must be to short circuit the output in case of DC on the output if anything goes wrong with the amplifier. Quad uses the same approach to avoid relay contacts in the output.
But the Quad amplifier uses current limiters in the output stage, while the Etalon amplifier has not. I hope the power supply is current limited... or else a DC-error might blow the output stage.
Steven
Old 25th April 2004, 09:07 PM   #7
PMA is offline PMA  Europe
PMA's Avatar
Yes, the triac is sometimes used as an output DC protection. Usually the fuse is connected between the output and the triac and the triac blows it when activated. Omitted here probably for the reason of fuse resistance.
Old 27th April 2004, 12:52 PM   #8
diyAudio Moderator Emeritus
There are 2 pots in the schematic. One is attached to base of BD139-BD140 pairs, I think it is Vbe multiplier for adjusting bias, and one is attached to its emitors, parrarel with 1kresistor. What is the second pot for? How to adjust to get the desired function?
Old 27th April 2004, 06:21 PM   #9
Steven's Avatar
The one on the left across the bases of the combined Vbe multiplier/error correction amplifier is for bias current adjustment.
The one on the right connected to the emitters of the Vbe multiplier/error correction amplifier is to adjust exact error cancellation. In that case the output impedance of the amplifier will be zero! Adjustment is easy: just connect a load resistor to the amplifier intermittently and look at the ouput voltage (sine wave) of the amplifier. Normally the output voltage will slightly decrease when loaded, but now adjust the preset such that the voltage will not drop. If you continue to change the preset, then the voltage will even increase when loaded (negative output resistance). The beauty of this preset arrangement is that the bias current and the error correction adjustment is independent of each other: it is (almost) free of interaction. Furthermore both adjustments operate for both halves of the output stage simultaneously, i.e. the positive half and the negative half.
Steven
Old 28th April 2004, 02:56 AM   #10
jam is offline jam  United States
jam's Avatar
Charles,
Wow! You are right. I much like the buffer between the first two stages. Aragon used in their amps. I wonder if replacing the 1k resistor with a current source would help? ( Rhetorical question...... )
Jam
P.S. The servo has got to go......................
schematics help just4copy Tubes / Valves 1 6th August 2009 11:44 AM
BOSE Schematics DENSO Schematics packer Car Audio 6 25th June 2007 10:55 AM
etalon pamaz Swap Meet 2 1st March 2005 07:41 PM
Amp Schematics up freedom Analogue Source 1 22nd November 2004 02:07 PM
Page generated in 0.12018 seconds (70.37% PHP - 29.63% MySQL) with 11 queries
