So, I turned on my Krell KSA-100S, and before the relay's kicked in, I shut it off accidentally when trying to hit the display button.
I then turned on the power again, and PUFF/SNAP/SMOKE!
The circuit on my power strip blew, and nothing else was damaged.
I am good with tube circuitry, but know very little about solid state.
Any suggestions where to start? I am going to go buy a torx bit so I can open her up, and look for the burnt components, but if anyone has any ideas where to look first, it may save me some time.
I'll report back when I open up the lid.
Thanks,
Bryan
Thanks,
Bryan
Hey Guys,
Well, after several hours of trouble shooting, I decided that I would not be able to find the problem. I think I will junk the amp, and pull out any goodies (68000uF 100V) caps for use in other projects. I paid 1500 for the amp a few years ago, and I could only imagine the cost of repairs would be near 500 with shipping and labor, and parts. (Wish it was a tube amp, as I'd have it fixed by now).
Anyway, I am curious to see what the other faults you guys have had were caused by, and at the end of the day, how much did the repair cost. Please keep me in the loop.
Best of luck,
Bryan
PS. Any suggestions for a good replacement in the 2-2.5K range?
Best of luck,
Bryan
I would not abandon it that soon, you could try and power the thing up on another low voltage power supply and see if the amp its self still works, if it does then its the PS.
Just turnin the amp on and off wont kill anything within the amplifier circuitry. it does sound PS related. If you have a simple PS simply turnin the amp on and off quickly doesnt damage anything.
I'd be wary about the PS caps mind you.
Hacknet - the sparks and flames lasted quite awhile. This sounds as if the PS caps were emptying out and "fueling" the fire so to speak, so id watch it.
- Is that smoke from my Krell KSA 100S?
