Is that smoke from my Krell KSA 100S?
Old 24th April 2004, 09:31 PM   #1
Bryan is offline Bryan  United States
Default Is that smoke from my Krell KSA 100S?
So, I turned on my Krell KSA-100S, and before the relay's kicked in, I shut it off accidentally when trying to hit the display button.
I then turned on the power again, and PUFF/SNAP/SMOKE!
The circuit on my power strip blew, and nothing else was damaged.
I am good with tube circuitry, but know very little about solid state.
Any suggestions where to start? I am going to go buy a torx bit so I can open her up, and look for the burnt components, but if anyone has any ideas where to look first, it may save me some time.
I'll report back when I open up the lid.
Thanks,
Bryan
Dont take life too seriously, you will never get out alive!
Old 24th April 2004, 11:52 PM   #2
Brian Donaldson is offline Brian Donaldson  United States
Brian Donaldson's Avatar
I'm not versed on Krell innards, but I would suspect that you turned it of and back on before some type of sort start circuit reset itself and the inrush burned something. But that's just a wild assed guss.
Old 24th April 2004, 11:58 PM   #3
Yeah, I was thinking the same myself....
I opened her up, but can not find any obviously burnt component....
Hmmm.........
Old 25th April 2004, 12:00 AM   #4
On Hiatus
SY's Avatar
First two things I'd check are fuses and rectifiers.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 25th April 2004, 06:15 AM   #5
mb is offline mb
I've owned a 100S for a number of years, and have had two caps blow on me. The PUFF/SNAP/SMOKE part sounds familiar. You may want to sniff out the caps. As a precaution, my dealer eventually changed the full set of main caps. That was two years back.
Old 25th April 2004, 07:27 AM   #6
hacknet is offline hacknet  Singapore
ive done it to my krell ksa150 too. the sparks and flames lasted quite awhile... i was stunned. i just sent it for repairs... did ask questions at that time.. what a waste.
Old 25th April 2004, 11:48 PM   #7
EchoWars is offline EchoWars  United States
EchoWars's Avatar
Why a waste??
...just curious...
Old 26th April 2004, 12:31 AM   #8
ChocoHolic is offline ChocoHolic  Germany
if you did not find any burned component....
may be you can find burned "track fuses" on the PCB??
good luck!
Old 27th April 2004, 03:59 PM   #9
Hey Guys,
Well, after several hours of trouble shooting, I decided that I would not be able to find the problem. I think I will junk the amp, and pull out any goodies (68000uF 100V) caps for use in other projects. I paid 1500 for the amp a few years ago, and I could only imagine the cost of repairs would be near 500 with shipping and labor, and parts. (Wish it was a tube amp, as I'd have it fixed by now).
Anyway, I am curious to see what the other faults you guys have had were caused by, and at the end of the day, how much did the repair cost. Please keep me in the loop.
Best of luck,
Bryan
PS. Any suggestions for a good replacement in the 2-2.5K range?
Old 27th April 2004, 04:06 PM   #10
5th element is offline 5th element  United Kingdom
5th element's Avatar
I would not abandon it that soon, you could try and power the thing up on another low voltage power supply and see if the amp its self still works, if it does then its the PS.
Just turnin the amp on and off wont kill anything within the amplifier circuitry. it does sound PS related. If you have a simple PS simply turnin the amp on and off quickly doesnt damage anything.
I'd be wary about the PS caps mind you.
Hacknet - the sparks and flames lasted quite awhile. This sounds as if the PS caps were emptying out and "fueling" the fire so to speak, so id watch it.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Is that smoke from my Krell KSA 100S?Hide this!Advertise here!
HELP!!!, KRELL KSA-100S Service Manual wanted!!!! fepablo Solid State 7 3rd November 2016 10:21 PM
diy proac studio 100s kjfarley Multi-Way 14 6th October 2009 07:37 PM
Krell KSA-100S HELP!! ej22g Solid State 0 15th February 2008 06:02 PM
Rebuilding a crossover network for Paradigm Studio 100s? Capital Multi-Way 3 21st November 2007 04:19 PM
Driver board on a Krell KSA 100S Serratoga Solid State 1 3rd January 2007 10:46 AM
