Old 24th April 2004, 02:51 PM   #1
MBK is offline MBK  Singapore
Default Fuse resistances?
I measured a 100 mA fuse to check if it's blown because I couldn't see the thread. Fuse was fine but DCR was about 9 Ohms. Nine Ohms!! I was stunned. That's quite a lot in PSU impedance I'm adding with my fuse.
Comments?
Old 24th April 2004, 02:55 PM   #2
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
never used a 100ma fuse but i think for that current 9 ohm is ok
Old 24th April 2004, 03:34 PM   #3
markp is offline markp  United States
At 100ma it needs that kind of resistance to heat up and fail with that little current.
If it sounds good... it is good!
Old 25th April 2004, 01:29 AM   #4
ClassD is offline ClassD  Australia
ClassD's Avatar
Send a message via MSN to ClassD
9 ohms x 100mA = 0.9V drop
Thats a pretty nasty drop!
Old 25th April 2004, 07:39 AM   #5
Electrons are yellow and more is better!
peranders's Avatar
No not really if you place it right, besides I think the value is a little bit high. How about nulling the resistance for the test cables and and removing oxide and dirt from fuse?
/Per-Anders (my first name) or P-A as my friends call me
Old 25th April 2004, 08:25 AM   #6
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I have measured some fuses I had lying out here...
100mA : 17 ohms [no brand, unknown specs]
200mA : 7.5 ohms ['dh' brand, unknown specs]
500mA : 2.2 ohms ['dh' brand, unknown specs]
1A : 0.1 ohms [no brand, unknown specs]
2A : 0.04 ohms [no brand, unknown specs]
4A : <0.01 ohms [no brand, unknown specs, copper filament]
5A : <0.01 ohms [no brand, unknown specs]
So DC resistance appears to reduce quickly with increasing current values
I've succesfully used those 100mA and 200mA fuses to protect the primaries of very small transformers connected to mains
Old 25th April 2004, 08:45 AM   #7
Yeah well... I use this 100 mA fuse for the mains of a small transformer, and what to do, it should have a fuse... I was just surprised at the value. Thanks all for your input...
Old 25th April 2004, 09:24 AM   #8
Eva's Avatar
Take into account that the primary of a 230V 20VA EI transformer may have 100ohms DC resistance and the secondary may show another 100ohms equivalent DCR as seen from the primary, so in the end, a 20VA transformer will show something like 200ohms primary impedance [shorted secondaries] and this means it will produce more than 20 times the voltage drop caused by a 9 ohm fuse
For tiny 2VA transformers you may measure primary DCR as high as 5Kohm [plus effective secondary resistance] so 9 ohms is fully negligible here
Old 25th April 2004, 12:25 PM   #9
ok, sounds reasonable.
That gives a strong reason though to not recommend fuses o speaker outputs, as some people use. Unless you use fuses as say, an Aleph's source resistor
Old 25th April 2004, 02:48 PM   #10
PMA is offline PMA  Europe
PMA's Avatar
Resistance of fuses by Schurter:
100mA 5.65 Ohm
1A 0.06 Ohm
5A 0.012 Ohm
Close to that described by Eva. And do not forget that the added resistance in the primary circuit of transformer is divided by N**2 to the secondary side, where N = V1/V2.
Transformer winding resistances AmpBuilder225 Tubes / Valves 5 4th June 2009 12:16 PM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
Why main fuse and not rail fuse? digital desire Solid State 10 3rd December 2006 08:07 PM
amp rating for fuse and fuse holder? riotubes Parts 5 27th August 2006 03:10 AM
Noise figure vs signal source resistances in JFETS datasheet rlim Solid State 25 19th December 2003 07:11 PM
Page generated in 0.11280 seconds (71.00% PHP - 29.00% MySQL) with 10 queries
