Hallo all,
I am Still pursueing the differential input and bridged (differential out) power amplifier. My main concern is how to couple the halfs together. Do they need to be closely coupled, via feedback, or can i just make 2 (nearly) identical power amps and feed the differential signal to it ? Your opinions please ! best regards Simon |
#2 |
Those are two separate issues, input and output.
A balanced input can be realized by any op amp, or the discrete equivalent of that if you prefer. A differential or bridged output is cam be realized using two amplifiers, one driven by the inverted output of the other. There are different ways to derive the inverted signal, from using an inverting op amp to using the negative feedback input of the second amp for input. If you are not familiar with these techniques, you need to do some homework -- here are some websites with more information. Elliot Sound Products has a nice tutorial on this: http://sound.westhost.com/project20.htm http://sound.westhost.com/project20.htm On the Hafler technical support site, there is a discrete op amp design for inverting the signal, and an example of using the negative feedback input. The op amp appears to be a Borbely design. Unfortunately, I think there is an error in the DH-202 schematic. The input is connected to the output, likely a drafting error. At any rate, here it is: http://www.hafler.com/techsupport/pd...tForDH-200.pdf http://www.hafler.com/techsupport/pd...tForDH-220.pdf |
#3 |
Simon, Have you been following the various aleph-X threads ?
This amplifier has differential input and output with the feedback loop (partly) making the error signal common mode. To me, this seems like a much more elegant solution than the more typical bridge arrangement where each half has it's own independant feedback loop. Dave (also playing with a differential power output stage) |
#4 |
No Sorry !
I did not follow the X threads. Maybe it is time to ! Today i managed to get nice results (in my simulator). Time for prototyping. |
#5 |
Seems like you are already taking feedback from both sides of the load to each half ! As I understand it this should cause errors to show up as common mode
Can I ask : [1] what is CMRR (with repect to the input) of this circuit like ? Does the output follow the common mode input signal ? [2] why did you not use a common (to both halves) LTP input circuitry ? Thanks for sharing you design Dave |
#6 |
Dont know yet If you got a hint to find out .................. Please let me know ! [2] why did you not use a common (to both halves) LTP input circuitry ? I have used LTP's. 1. 1 single ltp 2. a so called symmetrical 1. is nicely working in my simulator , curent feedback, but DC-offset is a bit of a pain and i do not like the way the feedback works. I tapped it rigt into the LTP leg again. 2. has voltage feedback and cannot get it to work wrt to DC-offset servo Thanks for sharing you design All of it comes from the web http://nov55.com/amr/amf1.htm http://home.swipnet.se/~w-50719/hifi/qrv06/index.html Simon |
#7 |
Forgot this
I want to feedback amp 1 to amp 2 and vice versa. It is almost impossible to get 2 identical amps so i need some kine od feedback from one to the other ! grtz Simon |
#8 |
If some knows how to calculate the CMRR for the above circuit, please let me know !
And if some one has a better scheme on feeding back amp 1 to amp 2 and vice versa, also...............please let me know ! best regards, Simon |
#9 |
DOES ANYONE HAVE OR KNOW WHERE ONE CAN PURCHASE A KIT TO BRIDGE THE HAFLER DF-200?
#10 |
hi
use the bridge adaptor from electronics australia very easy few easy to get components works bye thanking you andrew lebon |
| New LME Design -bridged / balanced inputs | AudioGrade | Solid State | 5 | 5th April 2009 04:35 PM |
| Balanced Pre AND Bridged Amp | amo | Chip Amps | 11 | 10th February 2004 02:36 AM |
| Bridged balanced psu | B.VDBOS | Chip Amps | 1 | 25th October 2003 11:19 AM |
| Why must balanced amps (or preamps) be bridged? | Bricolo | Pass Labs | 5 | 21st December 2002 11:42 AM |
| Balanced(bridged) Zen Ver.4 | stani772577 | Pass Labs | 2 | 10th December 2002 11:26 AM |
| Page generated in 0.12025 seconds (78.82% PHP - 21.18% MySQL) with 11 queries |
