To good to be true? - Page 3 - diyAudio
Old 1st May 2004, 09:09 PM   #21
gwolf is offline gwolf  Austria
gwolf's Avatar
Last year I have posted a shunt regulator design using positive feedback error correction:
Shunt Power Regulator Riddle
But it needs more than 2 transistors ...
Gerhard
Old 1st May 2004, 10:21 PM   #22
destroyer X's Avatar
Default Hello Elso, also boholm and all others
I know this is not only 2 transistors..... each side at leat tree...but, as i am using 33 years long, and i construct more than a hundred to friends use their 20 Amperes consumption SSB Radio Transmitters (consumption moves from miliamperes to 20 amperes in a matter of some microseconds) that i decided to show you.
A lot off supplies is almost this one.... the difference is that one is tested a lot, long time testing... some users died and his son is melting strong wires only to joke.... only to see it melt making output short circuit.
Do not answer your question.... but i send it to say you hello... also boholm and other friends.
Carlos
Carlos
Germans!.... watch this!:
https://www.youtube.com/watch?v=S63ecXwslas
Old 1st May 2004, 11:40 PM   #23
john curl's Avatar
This last schematic is representative of what a '2 transistor' regulator would normally look like. This was the original design for dc regulators in the '50's and '60's. Many early transistor design textbooks have this model.
Old 2nd May 2004, 12:06 AM   #24
johnnyx is offline johnnyx  United Kingdom
One of the transistors could be used as a zener, the reverse breakdown voltage of the base - emitter junction is about 6 to 7 volts. If the current is limited to a few mA, then it can be used as a zener substitute. (this is why the max voltage for TTL is specified as 6V, and why the max reverse VBE is 5V in most transistor data sheets.)
It's a noisy one though, I've seen it used as a white noise source, compared to a band - gap reference. Just like all zeners above about 5V, they are really "avalanche breakdowns", and this is a noisy process.
QB5 sub, too good to be true? Pashley Subwoofers 18 7th December 2014 01:57 PM
Single Tube RIAA preamp too good to be true? alexmoose Tubes / Valves 16 22nd October 2007 09:09 PM
True-RMS? star882 Parts 8 1st June 2007 03:35 AM
Is it true? rick57 Digital Source 4 31st October 2006 09:50 AM
Copyright ©1999-2017 diyAudio
