Old 25th April 2004, 04:58 AM   #21
slowhands's Avatar
Default Re: About vertical and lateral mosfet
Originally posted by lumanauw
I have built amp with K1058 pairs, it is lateral mosfet. In the manufacturer's datasheet it is definitely for audio use. But why I feel that with vertical mosfet (IRF) the sound just seems tobe have more character?
There is also controvercy about a certain device is good or bad for audio, like 4558 opamp.
Is it if a device is said for audio it is not automaticly that it will sound good?
The laterals are inferior for switching, compared to vertical MOSFETs. Their on resistance is too high, dissipation capability and currents too low. But they have the wonderful ability to share current in parallel, and avoid thermal runaway, for the simple reason that their transconductance decreases with temperature. This makes them ideal for audio use.
The main reason they have survived as a product is continued demand in the audio market. It is questionable whether there is enough demand to ensure long term availability from the manufacturers. The major player, Hitachi, has transferred its discrete semiconductor manufacturing to Renesas, a joint venture company (with Mitsubishi). Toshiba supplies a few parts, but is rumored to be ending production. There are several boutique semiconductor makers who produce them, but I personally would not bet my company on them.
The vertical MOSFETs have higher transconductance, lower on resistance, and higher power capability, and with care can perform as well or better. They usually need to be matched for parallel operation, and need temperature compensating bias generators for reliable operation in audio amps.
Best MOSFET for output stages millwood Solid State 136 4th June 2010 08:54 AM
Lateral MOSFET, How do I calculate power output synonymous Solid State 4 18th December 2007 07:54 AM
mosfet output conversion engel dela pena Solid State 15 13th October 2007 11:16 AM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 06:49 PM
output mosfet driver lazy Solid State 5 30th March 2002 05:13 AM
Page generated in 0.06270 seconds (82.46% PHP - 17.54% MySQL) with 10 queries
