#31 | |||||
I have this on breadboard. Works reasonably good. Quote:
Regards |
#32 | |
#33 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#34 | |
Not different from 'normal' servo loops. The fact that they are used in many 10.000's of amps is some indication that most probably it works. I concede that often the implementation isn't very good, but we have beaten that particular horse to death in this thread I would think. Jan Didden |
#35 |
OK, I'll back off a little but if you take signal from the DC servo intergrator you will not get an exact measure of the offset. The servo output is only a signal inside a feedback loop and tell you not much really.
#36 | |
You obviously have not taken my advice to read the former posts. The servo loop is not closed, because he wants to regulate the offset by hand. I said "an integrator LIKE the servo loop NORMALLY used to....". There is no closed servo loop and the integrator output is the offset voltage, at least above the low pass freq. And indeed that should be low enough so that there is no lf audio to slowly vary the apparent offset. Can I go now? Jan Didden |
#37 |
If one is not sure the amp being nulled may not dc offset slightly in the presence of some musical or test signals, best to dc null with no input signal applied or with a mute function enabled at the same time.
#38 | |
#39 |
This is meant to be implemented with a quad op amp. The first section is a differential integrator which will probably change - I drew it this way because I wanted to be able to select this circuit as a bias monitor as well as a offset monitor circuit. The second and third op amp sections and associated components comprise a high speed 'ideal' full wave rectifier. The final op amp stage acts as a bipolar current source to linearly control the LEDs intensity. 'Off' would correspond to 0 volts offset, in this case. I threw in D5 and R16 to limit sensitivity more than several tenths of to a couple volts away from the null range. All component values hypothetical
#40 | |
LOL ![]() guys you are making my day(s) by actually putting some effort into this whim of mine. Thanks everybody!
Jesus loves you. |
| Acceptable DC offset voltage | hags | Chip Amps | 2 | 8th March 2007 10:56 AM |
| Offset voltage | borges | Multi-Way | 3 | 17th May 2006 07:38 AM |
| How much output offset voltage is too much? | tubetvr | Solid State | 14 | 1st July 2004 10:47 PM |
| DC Offset voltage | phil | Solid State | 3 | 23rd October 2001 06:37 AM |
| DC offset voltage? | harbin | Solid State | 2 | 13th June 2001 06:51 PM |
