Offset Voltage Indicator?
Old 22nd April 2004, 10:13 AM   #21
moamps is offline moamps  Croatia
Dual LED offset indicator
+ offset red
- offset green
zero orange
set window with R9
Old 22nd April 2004, 12:09 PM   #22
boholm is offline boholm  Denmark
boholm's Avatar
I would prefer the LED not to light at all, when there is no DC. That's more logical to me. Agree or disagree?
Best regards
Bo
Old 22nd April 2004, 12:15 PM   #23
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
If you need an indicator to tell you that you have offset because you cannot hear it...
Old 22nd April 2004, 12:35 PM   #24
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
+ offset red
- offset green
zero orange
set window with R9
That's the idea, but I think in your circuit the window is always +/- .6V, independent of the pot. That's a pretty wide window for offset. I think that if you want to make the window variable (although I see no need for it), you need two pots, each across the diode and feed the fractional diode voltage to the comparator inputs.
You may also want to add a small positive feedback across the comparator to introduce some hysteresis, to avoid oscillations around the switching point.
You may also want to put R7, R9 in series with the comparator outputs to limit the LED current.
Lastly, place diodes across the LEDs in opposite polarity to avoid destroying them with too much reverse voltage.
Jan Didden
Old 22nd April 2004, 12:51 PM   #25
Stocker is offline Stocker  United States
Agree
haha... somebody found out the secret!
Jesus loves you.
Old 22nd April 2004, 01:35 PM   #26
Hi Jan,
thanks for yours correction.
Drawing error. Corrected.
....you need two pots, each across the diode and feed the fractional diode voltage to the comparator inputs.
Two pots aren't needed if window is symetrical.
You may also want to add a small positive feedback across the comparator to introduce some hysteresis, to avoid oscillations around the switching point.[/B]
OK, but not so important.
Led current is defined only with R7 and R9. In corrected schematic with R7+R10 and R9+R11.
Done.
Old 22nd April 2004, 01:49 PM   #27
jan.didden's Avatar
Looks like a winner. Clever, that R9 stuff. There may be some assymmetry if the ref diodes are not matched, but that's acceptable I would think.
Jan Didden
Old 22nd April 2004, 01:52 PM   #28
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
I'm sorry, but this won't work (I might be wrong).
1 LP-filter, preferable up to 3th or even 4th order, cut frequency 0.01-1 Hz. Those filters most also have low offset voltages. This is dependent how low DC voltage you want to detect, how advanced the filter should be.
2 Fullwave rectifier or two halfway rectifiers, one for positive and one for negative signals
3 Comparator with HYSTERESES!
4 Indicators
Filtering out a couple of millivolts from several volts or tenths of volts is a tricky business. Don't forget that DC is low frequency AC!
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 65 pcb's in order. 61 paid.
Old 22nd April 2004, 02:17 PM   #29
jan.didden's Avatar
Per-anders,
You may remember that this comparator stuff is preceded by an integrator like the servo loop normally used to null the offset. Please look up the previous posts.
Jan Didden
Old 22nd April 2004, 02:23 PM   #30
thoriated is offline thoriated  United States
Some amps may also DC offset slightly when producing a larger AC signal.
Offset Voltage Indicator?Hide this!Advertise here!
Acceptable DC offset voltage hags Chip Amps 2 8th March 2007 10:56 AM
Offset voltage borges Multi-Way 3 17th May 2006 07:38 AM
How much output offset voltage is too much? tubetvr Solid State 14 1st July 2004 10:47 PM
DC Offset voltage phil Solid State 3 23rd October 2001 06:37 AM
DC offset voltage? harbin Solid State 2 13th June 2001 06:51 PM
