Old 20th April 2004, 07:09 PM   #11
jan.didden's Avatar
Fred:
Give a man a fish and he has a great meal.
Learn a man how to fish and he eats for the rest of his life.
Jan Didden
Old 20th April 2004, 07:21 PM   #12
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
You gotta wonder, if you are going through the trouble of all those amps, comparators, etc etc etc why not just build the stupid servo? Worried about stability issues?
Old 20th April 2004, 08:08 PM   #13
Stocker is offline Stocker  United States
Default Re: Re: Re: Offset Voltage Indicator?
Originally posted by boholm
Well, I just left a little headroom, so that it wouldn't be triggered too often if the amplifier had some fluctuations
Excellent point.
Why would it always be on?
It wouldn't! I was thinking about another project I have been contemplating for a while!
if you go for a single LED then <snip>
Your idea of a bicolor LED seems like exactly what would be called for. That way you don't have to fool with an integrator at all.
And the fading would look good, but it shouldn't fade too slow. Otherwise you could turn the trimmer too far and past 0.
Well, you can always adjust it back... ...another excellent observation.
Janneman, I think Boholm nailed it with his one bi-color LED.
Originally posted by thoriated For offset,<snip> the LED whose brightness is approximately proportional to the current passing through it.
If you set the thing up right a plain comparator would (might? )be able to vary the voltage so the brightness variance would be controlled by it.
Depending on the amp, perhaps. Then again some people seem to despise servos, and others just like to tweak. Nobody ever said this was the easiest, simplest, most cost effective, most automatic or most elegant solution available. Depending on how unstable our theoretical amp's offsets are, this could end up being a pain in the booty to keep adjusting...
It's just an idea...
Jesus loves you.
Old 20th April 2004, 08:17 PM   #14
jan.didden's Avatar
Default Re: Re: Re: Re: Offset Voltage Indicator?
[/B]
A comparator by definition is an on/off switch, controlled by a reference. For instance, you may decide you can tolerate 10mV offset, you would have a comparator (really an opamp without feedback) with one input at 10mV and the other input at the offset. Whenever the offset gets above the reference, the output of the comparator switches. Depending on which inputs (- or +) have the ref or offset, the switching goes pos or neg. So if you take two comparators with opposite polarity connections, and wire-or the outputs (combining them with two diodes) you have a window comparator of which the combined output switches ON if the offset is outside the window (+ or - 10mV in this example).
The example in the quoted part above is no comparator at all but a linear amp whose output follows the offset to drive a variable current through the LED. That's not what he wanted.
In any case, you need an integrator to extract the offset from the amp output, which has a huge AC component completely swamping the relatively tiny offset. So, you need 3 opamps (yes I know you can do it with 2, but let's leave it at this for now).
Jan Didden
Old 20th April 2004, 09:48 PM   #15
Steven is offline Steven  Netherlands
Steven's Avatar
Default Re: Re: Re: Re: Re: Offset Voltage Indicator?
Make it a damped integrator. A normal integrator has an (almost) infinite gain for DC. Remember in this case, i.e. not being a servo, there is no feedback, so the LED wil go on after a while, even with a fraction of a mV offset.
Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973
Old 20th April 2004, 10:16 PM   #16
jwb's Avatar
Does it even need to be an integrator? I'll show my ignorance by suggesting you could just low pass the amp's output with a f(-3dB) ~ 1Hz and pass that to your DC-detecting window comparator
Old 21st April 2004, 05:59 AM   #17
jan.didden's Avatar
Indeed Steven, good point.
Jan Didden
Old 21st April 2004, 06:03 AM   #18
jan.didden's Avatar
No false modesty please!
Hmm yes, why not. The nice point of the integrator is its low output impedance to drive the comparators, but a low-pass filter for very low frequencies would need either a large cap, which may be relatively large and expensive, or a large R, which may influence the comparators. But other than that, yes sure.
Jan Didden
Old 21st April 2004, 02:03 PM   #19
A comparator by definition is an on/off switch, <snip>
Jan Didden
that stuff on my face would be egg.
Thank you and you are of course right about the comparator/ linear amp business. I am being too sloppy with my terminology in this thread!
also, when you use a quad op-amp like a TL074 or LM324, there are 4 in one package...
Jesus loves you.
Old 22nd April 2004, 05:55 AM   #20
hjelm is offline hjelm  Sweden
hjelm's Avatar
Default Analog Vu meter?
Wouldn't be a nice retro touch if you had a low pass filter and an analog voltmeter, + and - indication, instead of a LED? That way you have a relative feel for the actual offset and can trim it down.
Hjelm
Acceptable DC offset voltage hags Chip Amps 2 8th March 2007 10:56 AM
Offset voltage borges Multi-Way 3 17th May 2006 07:38 AM
How much output offset voltage is too much? tubetvr Solid State 14 1st July 2004 10:47 PM
DC Offset voltage phil Solid State 3 23rd October 2001 06:37 AM
DC offset voltage? harbin Solid State 2 13th June 2001 06:51 PM
Copyright ©1999-2013 diyAudio
