Hi every one i have an amp xplore xr3697 in the amplifier stage it uses ns108p and ns108n for the output power transistors, could someone please Who has this amp or an a
mp that uses this transistor tell if you found a Good replacement for this i search for the data sheet with no luck
In another post Perri says that can try tip35 monitoring the idle current, but could some one confirm they worked, i need 12 transistors and i Want to be certain if it is possible before i buy that the replacement is going to work
Thank you in advance for the help
