leach amp inductor smoking
Old 20th April 2004, 10:18 PM   #11
lucpes is offline lucpes  Romania
Send a message via Yahoo to lucpes
As always, nice work
I always wanted to ask if you have a more detailed description on the wire connectors used - eg mm for wire diameter, cost, a link for an online shop where one can buy them. I hate those screw-type ones, they cause lots problems if you use them 'frequently'.
Old 20th April 2004, 11:51 PM   #12
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
The connectors (in my picture) is Wago, german Spitzenklasse connectors but since the patent expired all the other big elephants in the connector business have got similar products but nothing is like the original.
www.wago.com
Did you know, Wago changes the sound to a more unconstipated sound. In fact Wago does more for the sound than Black Gate caps. The reason for this is the sharp spring which makes the sound very tight, in fact air tight ..... no.... but they are good. So good that they are used on ships, trains and also burried in the railways (tough enviroment and heavy vibrations).
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 65 pcb's in order. 59 paid.
Old 21st April 2004, 12:10 AM   #13
Thanks, these might free my amps from soldering power rails directly to PCB ... Now... errr... where to buy less than 420 connectors?
Old 21st April 2004, 02:50 PM   #14
JonMarsh is offline JonMarsh
The Leach amp uses feedforward compensation, from driver to inverting input. Furthermore, it has a low-pass filter on the output feedback, which makes it even more immune to hf instability with capacitive loads. In my experience with similar amps, if properly applied those two techniques keep an amp stable into capacitive loads.
Both the loop topology, the output stage configuration, and the actual wiring/layout dress seem to influence the stability- including factors of loop or local oscillation. For a Leach circuit the "safe"way to go without "qualifying" it under specific load conditions for the actual unit construction is to retain the inductor.
That said, I haven't built an amp requiring an output inductor in over ten years; I agree with you that the effect is deletrious to the output impedance and creates opportunities for audible interaction with speaker loads, and in general seems to reduce HF resolution. In many cases, better safe than sorry, though.
Best regards,
Jon
leach amp inductor smokingHide this!Advertise here!
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 02:15 PM
Zen V4 Smoking Q5 Diomedian Pass Labs 6 15th November 2005 02:46 PM
Resistor/Inductor at Leach Output BrianDonegan Solid State 10 22nd January 2005 06:22 AM
Smoking Amp jkramer Solid State 15 28th August 2004 04:17 PM
