Hey Thomas, hope you're doing good.
There isn't an "official" parts list or BOM (bill of material) for the NAP200, mostly due to we not knowing the parameters of which Naim uses to match and select their devices.
However there are some builds of NAP200 in the NAP140 thread. Since the schematic is almost deceivingly similar, builders for the 200 flocked into that thread as well.
Here's a PDF parts list for the NAP200 that I've followed to great success.
http://www.diyaudio.com/forums/solid-state/112453-nap-140-clone-amp-kit-ebay-218.html#post4609140
Following this post there's also a schematic with measurements by the same poster. However, I didn't follow everything in the schematic to the dot. Some people in the thread also did say that the schematic might not be 100% accurate or has the same measurements/etc compared to the real NAP200.
http://www.diyaudio.com/forums/solid-state/112453-nap-140-clone-amp-kit-ebay-218.html#post4609187
When I was building I referenced these two posts heavily and they really helped a lot. I don't think I can finish it without them and the help of everyone else in that thread.
This was a very fun build for me so I hope it will be for you too! Maybe you'd want to post into that thread instead for more technical support.
Cheers.
Cheers.
