Fisher RS-1020 questions and problems
Old 18th April 2004, 08:40 PM   #1
Jeffy74 is offline Jeffy74  Canada
Question Fisher RS-1020 questions and problems
I have to repair a Fisher Receiver RS-1020, but I found nothing on the net to help me. Habitually, I repair tube amp and I have the schematic...
1) Can someone give the specs? At least power output?
2) If someone have something to help me like a manual or your memory (!), it will surely help!
3) The problem is the left output. Only big hum and volume button has no effect on power of hum... I can heard hum on A and B of left channel. The right channel is ok and sound good and all buttons and pots works perfectly, tuner too. What can be the problem?
4) the 2 output modules were changed before (not by me) and don't like to be original. They look smaller because they don't fit in screws holes. Maybe one burn because it was not fixed properly on heat sink... What I see is "Fisher hybrid-ic power amplifier module PA-401" on a 10 pin black box soldered on a small pcb were a big cap had been changed too. Samething for other channel...
5) parts are available? I repair or throw it in garbage?
thank you for your help!
Jean-Francois
Fisher RS-1020 questions and problemsHide this!Advertise here!
NAD 1020 Preamp Problems gmilitano Solid State 72 28th May 2015 01:58 AM
Fisher 600 questions akimball442 Tubes / Valves 25 13th July 2008 07:47 PM
Fisher 400 questions pageboy Tubes / Valves 19 16th May 2008 02:44 AM
Fisher 500B OPT/Feedback Questions wrenchone Tubes / Valves 22 16th December 2005 10:06 PM
Copyright ©1999-2017 diyAudio
