Simple, powerful (100W-200W into 8ohm) amplifier schematic needed
Old 19th April 2004, 08:42 PM   #11
ChocoHolic is offline ChocoHolic  Germany
....got it ...
thanks destroyer. this circuit was new for me...
bye
markus
Old 20th April 2004, 10:40 AM   #12
ddog is offline ddog  Finland
Thanks for replies gyus/girls
Yes, it needs to be cheap, because it will be used outdoors, sometimes in rain (i doesn't be so bad thing then if it breaks or gets stolen if it's cheap). I also need lot's on desibels - it will be played in area bigger than 200mx300m and it would be nice if it can be heard anywhere, thats why lot's channles and power. Sound quality is not so important as said, just to get music play.
In home i have "hi-fi"-gear, GainClone, and for headphones Meier natural crossfeed amp and Szekeres fet follower, but we don't need that much hifi-systemin track.
Class-D amp surely could be good option in this application.
Thanks for everyone again
Old 22nd April 2004, 05:38 PM   #13
B.I.G is offline B.I.G  Romania
is that thing bridgeable ?
B.I.G
Old 22nd April 2004, 09:39 PM   #14
Hi Big!
I don't think that you can bridge this amp.
The center tapped output windings in push/pull configuration
already perform a similar thing like a bridge...
Bye
Markus
Old 23rd April 2004, 04:36 AM   #15
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Unhappy I do not know
I suppose may have some way....separating audio phase and input them separately into two units.....but output has DC voltage.....you will have to put at least big capacitors.....I really do not know how to make it.
But we have people in our forum that can give solution to almost everything.... and they also have knowledge to say something alike... forget it.... i cannot say that because knowledge is low... this way a lot of doubts happens in may mind..... maybe interconnecting low wire from the first amp, throught a big condenser to the hi position output of the second one.... and using the other two output wires as a new output using condenser too...... i do not know...maybe they will cancell the audio because of phase.....maybe not.
the reason i am entering here is some responsability because i put that schematic in our forum... and i feel afraid to create you some problem...or other friends troubles.
Carlos ....Destroyer X.....an old man (52), but new in forum and never studied electronics in some school....just burning fingers and reading magazines.... i am a Psychologist in degree and a TV broadcasting professional in the Technical area of maintenance , related to repair some fast problems, substitute fast burned machines, calibration in step by step manual procedure and equipment operation.
I am here to learn audio.
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 11th July 2013, 11:04 AM   #16
audiomachines is offline audiomachines  Philippines
Send a message via Yahoo to audiomachines
better image
Simple, powerful (100W-200W into 8ohm) amplifier schematic neededHide this!Advertise here!
crude, simple and powerful PP-amplifier Mikael Abdellah Tubes / Valves 11 25th April 2008 07:02 PM
HARM-23, Jfet 100W 8ohm roender Solid State 8 21st December 2006 11:12 AM
Powerful sub amplifier needed ostie01 Solid State 14 8th June 2006 01:54 AM
50w @ 8r / 100w @ 4r / 200w @ 2r costiss Solid State 25 24th April 2003 10:23 PM
Copyright ©1999-2017 diyAudio
