Audio Design Guide 2014 Power Follower
Joined 2000
I have some questions about the Andrea Ciuffoli 2014 Power Follower.
The new 2014 schematic and 2014 board do not include the output cap.
Is the output section built the same way as the older schematic?
I assume the positive speaker connection, if built like the '99 version, connects to the positive side of the output cap. This correct?
Is the 1k resistor needed across the speaker on the 2014 version
The 2014 schematic shows R10 and R11. Are both needed?
The '99 Power Follower Schematic is not label with a date. The 2014 schematic is labeled.
Thanks,
Vince
