Old 23rd April 2002, 12:23 PM   #11
mrfeedback's Avatar
Default Soldering iron
I have used a Hakko 926 Varitemp for years and it has never let me down.
Hakko has a very good range of tip sizes and shapes.
Buy only genuine Hakko replacement tips - There are Varnier copies but I have found them to be not the same longevity or quality.
PS - Varitemp is a Must for SMD work.
Regards, Eric.
Old 23rd April 2002, 05:05 PM   #12
dorkus is offline dorkus  United States
dorkus's Avatar
Send a message via AIM to dorkus
does it help to have a continuously variable station, or is it enough to have a few preset regulated temperatures? or do i need continuous adjustment with regulation?
Old 23rd April 2002, 09:07 PM   #13
Electrons are yellow and more is better!
peranders's Avatar
Default Not temperature sensitive
Most of SMD components are not very sensitive for temperature but it's an advantage if you can control the temperature.
I use Weller's 80 watts mini iron. Excellent! 0805, SOT-23 are the types I mostly use. Now and then SOT-363(0.63mm pitch) and Atmels AVR processor with 0.63 mm pitch.
0805 and SOT-23 are quite easy to solder by hand. The my pictures of my QSXM2 monster phono amp.
/Per-Anders (my first name) or P-A as my friends call me
Old 24th April 2002, 02:34 AM   #14
mrfeedback's Avatar
Continuous varitemp is better so you can set just the right temperature.
This temperature is dependant on tip size/type, pcb type, solder type, and component type/size.
Its a feeling thing that comes with experience.
Be prepared to use plenty of solder/flux, and clean the pcb with isopropyl alcohol afterwoods.
Regards, Eric.
Is this a practical HV supply? keantoken Power Supplies 16 27th May 2009 12:48 AM
Practical PSE thinking. Salas Tubes / Valves 10 8th December 2007 05:21 PM
practical choice for an amp jarthel Tubes / Valves 2 22nd June 2007 02:57 AM
Is this practical tenderland Tubes / Valves 10 1st April 2006 02:56 AM
Page generated in 0.07600 seconds (73.28% PHP - 26.72% MySQL) with 10 queries
