Old 17th April 2004, 07:06 AM   #11
Steve Eddy's Avatar
Originally posted by peranders
I think the best solution is to have a separate headphone amp with low gain, low noise, low distortion, low everything. In some cases you can connect the headphones directly to line out if the headhone has rather high impedance and/or the output has good drive capability.
Yup. And outputs that don't have the drive can be bolstered with a very simple buffer. Also, I'm looking into a passive solution using a 4:1 line level output transformer for outputs that have plenty of voltage gain and output voltage swing but insufficient current capabilities.
se
Old 17th April 2004, 07:33 AM   #12
destroyer X's Avatar
Default Using headphones....my god!
Here's the crazy amplifier.
Try to build an amplifier folks ... it is pure adrenaline!
Old 17th April 2004, 07:55 AM   #13
lucpes is offline lucpes  Europe
Send a message via Yahoo to lucpes
Originally posted by The Paulinator
These are 300 ohms per side, would any resistors really be necessary? I tried to run it the way that picture shows, but without the resistors, but there was a short somewhere. The volume was about what I would expect with the knob at that position if I were using using the headphone jacks, but there was a short somewhere in my solder connections (I knew it was a short because one side was louder than the other) and after about 5 or 6 seconds the amp went into protect mode.
Let's say that your amplifier puts out about 50W in 8 ohm impedance, with a voltage swing of 20V or something. For the headphones, you need around 0.15W to max 0.5W if they are really low sensitivity (and you feel the need to melt both the headphones and your ear wax), in 300R impedance, with a much lower voltage. Thus the resistors in the image.
Get the resistors (you might get away with 5W white ones & they're cheap), get 4 banana plugs for speakers, get a female 3.5mm jack, get 1m of microphone cable instead of 4wire shielded, cut that in half, make the connections as in the pic using one wire instead of two, make sure you take in account ground (red) & hot (black) from the amp, check everything THRICE, & only then plug it in (with the amp off). Use (electrical black duct tape)? to insulate everything that is hanging around and could touch anything.
Turn the amp on, take a cheap pair of cans, check the adapter, only AFTER that plug in your expensive set.
DO NOT experiment with your good set of cans; do it only until after you know what you're doing. The amp has protection, that's a good thing but don't play with the cans doing twisted connections that might slip and get your wallet thinner in seconds.
Old 17th April 2004, 02:39 PM   #14
maylar is offline maylar  United States
150 mw into 300 ohms is about the same voltage as 5 watts into 8 ohms. Without limiting resistors your volume control will be at the 1-2 watt level... whatever that is for your amp.
Personally I don't see a point in building a separate headphone amp unless you feel the need for a DIY project. I'd put 1000 ohm 1/2 watt resistors in series with the headphones and see how it sounds. Crank it up slowly...
dave
Old 17th April 2004, 02:57 PM   #15
Years ago I connected some high impedance low sensitivity
Yamaha "isodynamic" heaphones directly to the output of
a NAD3020 amplifier without any problems whatsoever.
However if you do not have volume issues, you will have
noise issues with direct connection. If you want low
impedance drive for your phones it would be best to
connnect them via step down transformers to the amp,
or use a dedicated low impedance headphone amplifier.
sreten.
Old 17th April 2004, 07:08 PM   #16
Most amps already have resistors (680R or so) in series on their headphone outputs so no need to do that
The thing here is to keep a low output impedance, that's why I brought up that specific adapter.
Wanted: High-end headphones & IEMs, even if battered or broken Spasticteapot Swap Meet 0 21st September 2008 01:33 AM
Connecting headphones to guitar amp speaker output mike6182 Instruments and Amps 6 21st November 2007 10:20 AM
AMPLIFIER ( MIC imput, HEADPHONES output)?? medogrizli Chip Amps 2 30th May 2007 04:30 AM
AMPLIFIER ( MIC imput, HEADPHONES output)?? medogrizli Solid State 1 28th May 2007 12:31 PM
Headphones output to line level Simpleton Parts 1 13th May 2007 09:54 PM
Page generated in 0.10420 seconds (79.88% PHP - 20.12% MySQL) with 11 queries
