Help needed balance pot
Old 13th June 2018, 09:56 PM   #11
MAAC0 is offline MAAC0  Portugal
My Vestax MDM401 mixer uses the same principle. What I did was removing the balance pot and shunting it for a quick fix .. Now have to find something similar.
I believe it behaves as there were one pot for each channel. That means when You attenuate one channel, the other doesn't increase level. The channels are indeed separated. On my Vintage Pioneer SA606 it is single ganged. I would try both and see how they behave.
Old 14th June 2018, 11:36 AM   #12
Depaj is offline Depaj  France
That's it yes, I just shorted IN/OUT on the connector for now to do further testing on the rest of the amp but I will need to replace it. Using a single gang pot means that the signal doesn't actually get through the pot, isn't that in it self a reason to use this method ?
Old 27th June 2018, 04:06 PM   #13
I finally decided to go with a 250k MN stereo guitar Balance/blend potentiometer. The shaft was knurled so I had to file it flat to work with the knobs, other than that it works like a charm.
Help needed balance potHide this!Advertise here!
Alps 100K Stereo Balance Pot - Needed SyncTronX Swap Meet 13 10th January 2017 04:30 PM
To Balance, or not to Balance, that is the question... Obisix Solid State 16 8th February 2016 05:35 AM
Balance Pot redrooster Parts 4 30th June 2014 12:00 PM
Re: Balance to Un-Balance Converter SSDIY Solid State 23 20th March 2013 01:59 PM
Can I Add a Balance Pot? Bojack Analog Line Level 0 2nd November 2010 02:30 PM
