"vintage" quasi complementary power amp
Old 11th June 2018, 11:36 PM   #11
steveu is offline steveu  United States
Lets try this again with collectors connected:
Old 12th June 2018, 08:23 AM   #12
catd is offline catd  Europe
catd's Avatar
Hello steveu,
Thank you for your posts.
Originally Posted by steveu View Post
I assume the real amp has a build-out choke+resistor...
That's right, there is the mentioned choke in the real amp, contained in a speaker-on-delay extra-PCB. (could be seen in one of the pictures under the link in first post)
The current limit protection should have worked without causing problems so that bothers me. Do you have some kind of passive crossover with a series resonance that is ~shorting the amp?
It's more than 35 years ago when this occurs and I remember only, that I omitted this protection and all was OK.
Speakers was/are 3-way with simple 12db passive crossover.
As I wrote, I want to stay with the quasi complementary approach, and see what is possible to make this a bit better.
But I will try your suggestions if possible so far.
Old 13th June 2018, 12:13 PM   #13
BTW, do the math and you find the original current protection was set to limit at 7 Ohms, not 4, not even 6.
Old 13th June 2018, 02:30 PM   #14
catd's Avatar
That's right.
I have one original PCB/Circuit of the Amp as shown in the first pic/post; was built-in to a guitar amp at the time.
A couple of weeks ago I made a test with generator and oscilloscope whether it still works after all the years.
It does.
With 4Ohm output load it started clipping/limiting at about 20V amplitude.
( The amp was sold back then as 160W sin at 2-16 Ohm. )
Old 18th June 2018, 04:26 PM   #15
catd's Avatar
Hello...
This is the last version of the amplifier.
The outcome of the simulations is fine for me.
It was possible to put all parts on a PCB layout at the given PCB size.
So I'll build it up real in the near future and test it and post the result here.
"vintage" quasi complementary power amp-quasi_amp_014-jpg
Old 19th June 2018, 10:06 AM   #16
Bix is offline Bix  Australia
Bix's Avatar
Cool, I look forward to your build. Thanks for posting your schematic.
Live and let live
Old 19th June 2018, 02:18 PM   #17
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Q11 supposedly emulates a Baxandall diode. What about replacing it by a 1N400x?
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 19th June 2018, 03:05 PM   #18
catd's Avatar
Yes, Q11=Baxandall-Diode.
1N400x instead? Why not?
It will be possible to replace the transistor by a diode in the real PCB-built, and see/hear if it makes any difference.
I read somewhere: -a transdiode would fit better, if one chose the right transistor (same as in positive half), or so-, can't remember, where.
Therefore I made the layout with the possibility on the PCB.
Old 19th June 2018, 04:41 PM   #19
john_ellis is offline john_ellis  United Kingdom
R5 and R18 should be the same- can't read the diagram, are they?
C7 is usually needed in quasi amps to suppress lower half oscillation. Might still be needed even with a complementary OP stage. I too recommend changing to fully complementary. There is no advantage with current transistors for NPN only. There should be a resistor in series with the collectors of the lower half OP transistors which is also connected to the anode end of the diode-connected transistor. You won't need that if you swap to PNP's, saving a voltage drop.
Rather than increasing C5 you might reduce the OLG with emitter degeneration resistors.
Old 19th June 2018, 06:08 PM   #20
Why? I think there's a demand for a resistor, or resistors, between the lower power device(s) and the output bus only if there's a current limiter.
Yes, in this case the resistors remain in the emitter circuitries.
Best regards!
"vintage" quasi complementary power ampHide this!Advertise here!
Quasi complementary outputs in a full complementary circuit xeclipse Solid State 12 11th January 2011 07:35 PM
Quasi complementary outputs in a full complementary circuit xeclipse Solid State 0 26th December 2010 07:08 PM
"An Adjustment-Free Complementary Power Amplifier" by J.Diamond jez Solid State 28 22nd August 2010 11:33 PM
Single supply quasi complementary mosfet power amp slideman82 Solid State 8 7th March 2009 12:25 AM
(Quasi)complementary JFET power amplfier R-K Rønningstad Pass Labs 21 15th July 2007 06:21 PM
