Hi everyone,
I have recently purchased a 2nd hand A400 on ebay and unfortunately there is a slight but audible distortion on the right hand channel when signal is present. The distortion sounds like a partially blown speaker (I spent an hour or so checking my speakers over before realising it was coming from the amp!) – a sort of signal dependant mechanical buzzing. It is most apparent with a low level mid-range signal such as an a bass guitar note and is present using all inputs and also on the right headphone output. Does anyone have any suggestions as to what may be causing the distortion? Also, I did a search on this forum and found a thread regarding A400 schematics. Would anyone be kind enough to email me the schematics? Thanks, Duncan |
#2 |
possible o/c transistor - tried cheching output transistor(s)
.:Ride the Lightning...Feel the Thunder:. - Technics Triple Thunder www.welcome.to/Technics |
#3 |
Two things I would check for are bad transistors and dried up electrolytics.
USMPS http://groups.yahoo.com/group/switchmode/ |
#4 |
Also no bias can be audible as crackling. Check bias too.
#5 |
Had some similar problems and the culprit was a blown diode
http://sound.westhost.com/articles.htm check these first: http://sound.westhost.com/troubleshooting.htm http://margo.student.utwente.nl/el/audio/amphelp.htm |
#6 |
Thanks for your replies. Since my initial post I've had a closer inspection of the PCB and noticed some evidence of electrolyte leakage which could have come from one of two caps which I will try replacing.
Without schematics (and with little familiarity of amp design) I find it quite difficult to do fault diagnostics on a good channel vs faulty channel basis. Thanks again. |
#7 |
Replacing all the low value electrolytics you find on both L/R PCBs isn't a bad idea at all + it's cheap.
#8 |
Hi all,
I've replaced the old PSU smoothing Elna black/gold caps with Panasonic TSUP as I couldn't source any better of the same spec. I'm soon about to replace the coupling caps with Audyn MKP QS , hoping this will make a worthwhile improvement. I'm also replacing some of the larger Elna/Nichicons for the L/R channels with Black Gates. Any recommendations for mods to the A400, including my choice of the Audyn MKP QS would be appreciated. Thanks, Dav |
| pioneer a400 | reddish75 | Solid State | 24 | 21st September 2008 11:14 PM |
| pioneer a400 schematic | reddish75 | Solid State | 2 | 19th September 2008 11:31 PM |
| Need help with hum and faint left channel on my S5 Electronics kit | Neville | Tubes / Valves | 4 | 15th January 2007 10:58 PM |
| Buzz on Pioneer A400 | Smiffy | Solid State | 4 | 16th January 2006 05:38 PM |
| One channel has VERY faint output | jjdche | Car Audio | 4 | 18th March 2004 04:22 PM |
| Page generated in 0.09214 seconds (72.36% PHP - 27.64% MySQL) with 10 queries |
