I am really confused related to that.
You are entirely correct, its true that gain normally is the values you told.... was an example. I will like to have a formula to calculate, matching without soldering and dessoldering because i do not know to simulate changing gains.... english is not my language to, auch sprach deutsch nichst. The size of a rope, or a wire is double his half part..... also three times his third part...... if someone defines a rule to every kind of wire...not knowing their measure..... this is Intelligence and this can be applied to every wire on the earth..... you win! Also you entered a football field till its middle point...... before that you geting out.... aplied to every field.... thats it! Always you..... Nordic people...... always you with bigger intelligence!.... thats interesting. I want a formula...... but i think i will discover...Mr Pass ( a honor to me) had some idea.... also Mr Jan Dupont (other sacred electronic hot brain) helped me. Your gift is: You are in a prison You are the man arrested, locked inside You have two doors... you decide where the doors are You have two policeman One of those policeman only says truth The other policeman lyes all the time....untruth (lies) not true You do not know wich one is the one that say real things So you do not know the bad one too You have two answers......each answer directed to each policeman stand by in front off those doors One door goes to poison gaz chamber Other door goes to freedom If you result this you will have, probably a very high Intelligence Quocient...... thats bad!....because the one that understand more also feel more sadness related to life.....see more.... fell more....but will be helpfull to society and also your family and children... congratulations.... Off course cannot use child questions alike: - Are you a dog? Can solute with logics....Mathematics.... and much more. The big champion decide that in 31 seconds.....Mr Albert Einstein... in his scape from Nazi.... in Sweden i suppose.... in the house of Ottmar Albert furrer where he scape from persecution.... as you know Einstein was a Juden, in the presence of my army Sargeant, Ottmar's son Ottmar Herbert Furrer that heard that storie and pass it to me in the seventies. My brother is trying since 1995....... i spent 6 days thinking Good Lock..... auf wiederheren unt lesen Destroyer because i burn components..... X is extra, super, hiper destructor!
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine. |
#2 |
Q0 : Is there a door going to freedom?
Q1 : Does the door behind you go to freedom? [Yes=1, No=0] Correct_door = Answer0 XOR Answer1 |
#3 |
Hi Carlos
A whole thread in my honor And I cannot speak portuguese. A little spanish, but that is not quite the same - I know A formula you ask: The transistors alone: I-out = HFE-driver * HFE-powertrans * I-in Including the resistors: I-out= (HFE-d*HFE-p*(I-in - 0,65/R1)) + HFE-p*(I-in - 0,65/R2) + HFE-d*(I-in - 0,65/R1) + I-in HFE-d: HFE of driver transistor HFE-p: HFE of power transistor I-in: Input current of driver transistor I-out: Output current of power transistor, emitter R1: Resistor at driver R2: Resistor at power transistor Not that you need it, bacause you do not need that kind of accuracy. There is too much tolerance on the HFE (unless you measure them, but they can measure differently dependant on the test current - i.e. not linear). To choose from 2 doors: The lying policeman says: "One door goes to gas chamber" The true telling cop says: "The other door leads to freedom" Please No more headaches . . .
Best regards Bo |
#4 |
Lets fix a cop and a door..... lets do the left door our main door for a while.
Lets now fix a tell true cop and the real freedom door in the left side the way we are fixing now. If you ask if there was a freedom door you will lose one question with an already known answer....because the problem guarantees that one door will go to freedom. If the tell true cop is the man in the left door he will say that is true that exists in the reality the freedom door.... continue to ask him the second question related if this left door is the freedom door he will say yes If the not true teller cop is the man in the left door, he will say that do freedom door has no existence and this way you will know he is the not true teller cop.... so, this way is not a permitted question because is too much obvious and test is to big brains.... like your certainly, just because you have courage enought to expose yourself, this indicates you have knowledge how clever you are, and this is because you test yourself life long and know you are at least an special thinking person. But the correct solution that i could find.... and i do not know the mathematics formula answer......just people inform me that can be answered using Mathematics.... i will expose.... so.... if you want to keep on trying do not read the solution that i will expose now! The answer is just one for each cop....but nobody says that you cannot ask cop A to answer Cop B and give the answer to you.... Next you invert.... ask Cop B to go near Cop A and ask him "whats the freedom door?" This way...... because you have an always lier (lyer... tell not true) in your communication...... always a not true door will appear as the freedom door...... so, you can open the other door and have your freedom. Mr Boholm..... i understood very well now..... everything became clear to me.... and i am very happy to met you..... unfortunattelly i made a test and the audio was not good enought.... do not know the transistors faulty or bad .....or the way i force them to work correctly..... i really do not know... take a look in the text i write about this, .... please. Eva.... you wellcome.... thanks a lot....maybe you had the solution and my last 2 neuronius burn to understand you..... maybe you found the solution and i did not understand you..... but i thank you by the kindness and attention and please, call me everytime you want or need.... i will be happy to have news from you two. Thanks your attention Carlos
| SY, answer this: | audioPT | Everything Else | 3 | 13th January 2006 05:42 PM |
| Page generated in 0.10610 seconds (73.27% PHP - 26.73% MySQL) with 10 queries |
