Apex 1010VA with (4) 37.5 secondaries, wiring question
Old 14th July 2002, 08:45 AM   #11
acliao is offline acliao
Send a message via ICQ to acliao Send a message via AIM to acliao
I Just received my Toroid from Apex today and I am confused by the wiring color coding. Can someone please help?
6 Primary (I believe as there are short wires)
- Black
- Blue
- White
- Gray
- Purple &
- Red
8 Secondary
- Yellow (solid & Stripe)
- Orange (solid & Stripe)
- Black (solid & Stripe)
- Red (solid & stripe)
From Grey's posting above, I already found out the Secondaries--
2x Yellow to bridge
2x Orange to ground
2x Red to ground
2x Black to bridge
BUT, how do I wire the primaries? Thank you for your help.
Old 14th July 2002, 10:03 AM   #12
Thomas is offline Thomas  Denmark
Thomas's Avatar
The 1010VA's only have 2 primary windings. What transformer did you buy? I don't see any white or red primary leads here.
If you indeed got the 1010VA from ToroidTech, you wire them for 110V/120V in parallel as Grey did, or 220V/230V/240V in serial as I did.
If you are confused, the thick wires are the secondaries and the thinner are the primarys.
Old 14th July 2002, 03:33 PM   #13
Ok, Just checked the Toroid I got. The part number is TC50008, VA 1010P/P, Input 2x100-120VAC @ 50/60Hz. I do not see any brown wire but have 3 extra leads, black, white and red (pink?) Please help. Thank you.
Old 14th July 2002, 04:20 PM   #14
Thomas's Avatar
My three transformers have all written TR50012 on them. If yours are different from mine, I cannot give the colours to you.
As you wrote, the transformer has 2x primarys. This means you should have four leads for the pri.windings. The four leads should be thinner then the secondary taps. If you only have 3 "thinner" leads, this could mean one of them is common for both pri.windings. You also mentioned 6 primary leads, so maby you have 2 "sets" of them. You realy should try a ohm-meter to find out your self.
Old 15th July 2002, 04:18 AM   #15
Apex Jr is offline Apex Jr  United States
These were part of the same deal and ARE the same as the
TR 50012 types.....with the same markings..
color and wiring are different............
BTW: These came out of Mondial amps
Primary:
Grey 120V
White 100V
Blue 0
Brown 120V
Pink 100V
Violet 0
Secondarys
37.5Volts on these taps
Yellow and Orange
Yellow/White & Orange /White
Red/White & Black/White
Red & Black
Hope this helps
Steve
Apex Jr
www.apexjr.com
Apex 1010VA with (4) 37.5 secondaries, wiring questionHide this!Advertise here!
Wiring Filaments with Center Tapped Secondaries JBasham Tubes / Valves 22 20th March 2009 09:24 PM
Dual secondaries -- quick question redrabbit Power Supplies 9 11th October 2008 10:28 AM
Wiring secondaries of two power trafo's in parallel? Klimon Tubes / Valves 5 21st October 2005 02:22 AM
'Tube' preamp bad for measurement mic? also Apex mic question morbo Multi-Way 10 23rd March 2005 11:19 AM
transformer secondaries question endia Chip Amps 12 26th January 2005 08:41 PM
