CCS reposting
CCS reposting
Old 22nd April 2002, 02:55 PM   #1
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
Default CCS reposting
Ok, sorry, I try again !. This time I'm trying to send a jpg image file.
Hello All,
This 2 terminal constant current source circuit is shown in a recent EW magazine - Circuit Ideas.
"Constant current diode look-alike" ....... .........The 2 terminal circuit shown here is composed of a pair of complimentary constant current sources, where each provides a constant current for the voltage reference of the other, thereby improving performance.
Compliance is excellent and the current can be set to almost any value.
Power dissipation and voltage withstand are limited only by the transistors chosen.
The circuit can be made up on a tiny piece of stripboard, and makes an excellent replacement for current setting resistors in many audio power amplifiers.
David N J White
Bearsden
Glasgow
G3
[IMG]c:\ccs 317.jpg[/IMG]
The formula given is - Iconst = 2 * [(Vf - Vbe)/ R], where
Vf = Led voltage drop,
Vbe = vbe for Tr1 & Tr2,
R = R1 = R2.
Simulation with red leds shows
10v - 8.810 mA
20v - 8.833 mA
30v - 8.854 mA
40v - 8.873 mA
50v - 8.891 ma
Maybe this is old hat to some of us, maybe useful to others of us.
Modifications/improvements ?.
Is this good performance ?.
Is there more to be known regarding application of ccs's.
HH thoughts on green leds ?.
Regards, Eric.
Old 22nd April 2002, 04:37 PM   #2
tiroth is offline tiroth  United States
mrfeedback, please use the "attach file" box on your .jpg image. This will upload it to the diyaudio server. It is smart enough to know that a .jpg is an image it can display. If you send a .bmp this way it will be attached, but not displayed.
Old 22nd April 2002, 05:30 PM   #3
mrfeedback's Avatar
Next try......
Old 22nd April 2002, 05:35 PM   #4
mrfeedback's Avatar
Default next ......
[IMG]C:\ccs 317.jpg[/IMG]
Old 22nd April 2002, 05:37 PM   #5
mrfeedback's Avatar
can anybody see the image ?
Harry ?.
Old 22nd April 2002, 05:51 PM   #6
stadams is offline stadams
I can see it.
-Todd
Old 22nd April 2002, 05:52 PM   #7
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
CCS reposting
I can see it! I actually deleted an attempt to put my guess of a picture in for discussion since you were not yet successful.
mlloyd1
Old 22nd April 2002, 06:14 PM   #8
mrfeedback's Avatar
Ahhh, success at last. Thanks for the replies telling me so !.
Can you read the previous text too ?.
Comments etc ?.
Regards, Eric.
Old 22nd April 2002, 06:53 PM   #9
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
CCS reposting
If you want an even more extreme current source use cascodes and if you want even more use darlington connection for the "upper" transistors.
Instead of LED (temperature sensitive and not very predictable) use a LM431! Now the current source starts to look my kind of style (overkill and monster design)!
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 41 pcb's in interest.
Old 23rd April 2002, 12:34 PM   #10
Geoff is offline Geoff  United Kingdom
Eric
Thanks for posting the schematic (eventually :-). Apart from the advantage of it being a two terminal arrangement, I don't see too much benefit in the circuit. In simulation, the current variations with ambient temperature and load are slightly greater than those for a standard LED/transistor ccs. The current change with supply rail voltage variations is however significantly better, but this is only of relevance if unregulated supplies are used.
The standard two-transistor ccs has better temperature characteristics and far better load tolerance than either of the LED circuits and is mid-way between the two LED circuits so far as current v supply rail voltage is concerned.
The two-transistor ccs can be made into a two terminal arrangement, as shown below, using a similar philosophy to the circuit you posted. With this ccs, the temperature and load characteristics are similar to those of a standard two-transistor ccs and the current change with supply rail variations betters David White's circuit by a factor of 10.
Geoff
CCS repostingHide this!Advertise here!
