CCS reposting
CCS reposting
Old 23rd April 2002, 01:59 PM   #11
jam is offline jam  United States
jam's Avatar
Geoff,
What an excellent idea! I wonder if bonding Q2 and Q3 togther thermally would provide any thermal stability benefits?
Jam
Old 23rd April 2002, 03:17 PM   #12
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default peranders, could you post an ultimate current source?
As you may know these things are becoming quite popular with tube/valve people. I just installed the C4S from the bottlehead site on my tube preamp, but I was wondering if there was a way to improve on the design. Needless to say I am no EE.
Bas
Old 23rd April 2002, 03:46 PM   #13
Geoff is offline Geoff  United Kingdom
Jam
Difficult to answer your question without actually building and testing the circuit. In simulation, I simply raised the global temperature. A 10degC rise in junction temperature gave a 2.5% current variation for this arrangement, compared with 3.5% for the LED schematic. Current variation with load (10ohm to 1kohm) was 0.1%, the same as the two-transistor ccs, compared with approximately 0.75% for the two LED versions. For a 50V supply rail modulated with a 2Vpeak sine wave, the current variation was 0.004% for the circuit I posted, 0.04% for the White circuit, 0.18% for a standard two-transistor ccs and 0.37% for the LED/transistor version.
Geoff
Old 23rd April 2002, 04:48 PM   #14
I should have mentioned in my original post that, for the 4-transistor ccs, R1 = R2 = R and Iconst is 2 * Vbe / R. For initial calculations, R = 1.3 / Iconst is sufficiently accurate.
Old 23rd April 2002, 05:17 PM   #15
sonnya is offline sonnya  Denmark
sonnya's Avatar
Hi Geoff
Which BJT did you use in the simulation?
Sonny
Old 23rd April 2002, 05:46 PM   #16
Sonny
BC550 & BC560, with R1 and R2 set at 120ohm. I adjusted all versions of the ccs to give a current of between 10 and 11mA, which was the figure the White circuit gave with the resistor value shown on Eric's schematic.
I must stress that the figures I obtained should be treated as approximate since I made no attempt to optimise each circuit. However, I believe that they are sufficiently accurate to permit an initial comparison to be made. The main disadvantage I see with the 4-transistor or 2-LED/2-transistor ccs is that a higher supply rail voltage may be needed in certain applications due to the larger PD across the ccs.
Geoff
Old 23rd April 2002, 06:35 PM   #17
tiroth is offline tiroth  United States
Geoff
I just the other day was drawing up a CCS, and those are exactly the transistors I was planning to use! I'll have to try out your circuit.
Old 23rd April 2002, 07:53 PM   #18
HarryHaller is offline HarryHaller  United States
Banned
Default CCSWTMP
hhmmm.............
Old 23rd April 2002, 08:09 PM   #19
sonnya's Avatar
Originally posted by Geoff
Sonny
Geoff
I can understand that, but it could be fine for something like currentsource for an input diff-pair or for driving a bunch off currentmirrors with a constant current source. It will not be affected that much by ripple on the supply rails.
I think your sims shows the fine result you can get with a 4-BJT solution compared to a "simple" current source.
Sonny
Old 23rd April 2002, 08:12 PM   #20
Harry
Your's is longer than mine :-( Is this a competition to see who can design the most complicated current source?
Tiroth
By all means try the circuit I posted. However, if your supply rails are regulated (which they should be for low current circuits) I do not see that there will be any performance improvement over a simple 2-transistor ccs. An alternative, if the supply rail voltage does fluctuate, is a jfet (with gate and source connected to from a ccs) in place of collector resistor on the control transistor. The 4-transistor circuit only comes into its own if a two-terminal ccs is required to say replace a resistor in an existing circuit where it is difficult to provide the earth connection required by the simple 2-transistor circuit.
Don't take my reference to the BC550/BC560 as a recommendation (though I have no complaints with these transistors). I simply use the models for these devices when I want a small-signal transistor model since I have tested the models and have found that the results have good correspondence with the datasheet information.
Geoff
CCS repostingHide this!Advertise here!
